ES does not return data due to threadpool limit
hi,
I have such errors in ES logs (and my dashboards don’t show up). ES 5.5.2, Graylog 2.3.1, about 30T of data in 12 ES nodes.
org.elasticsearch.transport.RemoteTransportException: [es-graylog-node04][ES-node-IP:9300][indices:data/read/search[phase/query]]
Caused by: org.elasticsearch.common.util.concurrent.EsRejectedExecutionException: rejected execution of org.elasticsearch.transport.TcpTransport$RequestHandler@652844fa on EsThreadPoolExecutor[search, queue capacity = 1000, org.elasticsearch.common.util.concurrent.EsThreadPoolExecutor@5c799098[Running, pool size = 13, active threads = 13, queued tasks = 1000, completed tasks = 1634784]]
What is you suggestion - more memory to ES nodes, or something else?
Increasing threadpool sounds like not solving the issue, or is the Graylog way of using ES such that it would be beneficial?
Your Elasticsearch cluster can’t keep up with the throughput of messages sent to it by Graylog.
In general, you need to tune your Elasticsearch cluster, provide more hardware resources, or reduce the message throughput.
For anything more specific, your post is lacking relevant details.
