Error while running migration after upgrade to 4.0.17
I’ve got a problem with Graylog migration after upgrade to 4.0.17.
This Graylog started as 2.5.2 with MongoDB 2.6.10 and Elasticsearch 5.6.16. Migration path was:
Graylog: 2.5.2-1 → 3.0.2-1 → 3.1.4-1 → 3.2.6-1 → 3.3.17-1 → 4.0.17-1
MongoDB: 2.6.10 → 3.0.15 → 3.2.22 → 3.4.24 → 3.6.23 → 4.0.28 → 4.2.22
Elasticsearch: 5.6.16 → 6.8.23
After upgrade from 3.3.17 to 4.0.17 I’m getting errors with migration:
`2022-09-28T14:56:45.915+02:00
ERROR [ConfigurationManagementPeriodical] Error while running migration
<GrantsMetaMigration{2020-08-03T12:08:00Z}>
java.lang.RuntimeException: IOException encountered while reading from a
 byte array input stream at
org.mongojack.internal.stream.JacksonDBDecoder.decode(JacksonDBDecoder.java:67)
 ~[graylog.jar:?] at
com.mongodb.DBDecoderAdapter.decode(DBDecoderAdapter.java:49)
~[graylog.jar:?] at
com.mongodb.DBDecoderAdapter.decode(DBDecoderAdapter.java:29)
~[graylog.jar:?] at
com.mongodb.operation.CommandResultArrayCodec.decode(CommandResultArrayCodec.java:52)
 ~[graylog.jar:?] at
com.mongodb.operation.CommandResultDocumentCodec.readValue(CommandResultDocumentCodec.java:60)
 ~[graylog.jar:?] at
org.bson.codecs.BsonDocumentCodec.decode(BsonDocumentCodec.java:84)
~[graylog.jar:?] at
org.bson.codecs.BsonDocumentCodec.decode(BsonDocumentCodec.java:41)
~[graylog.jar:?] at
org.bson.internal.LazyCodec.decode(LazyCodec.java:48) ~[graylog.jar:?]
at
org.bson.codecs.BsonDocumentCodec.readValue(BsonDocumentCodec.java:101)
~[graylog.jar:?] at
com.mongodb.operation.CommandResultDocumentCodec.readValue(CommandResultDocumentCodec.java:63)
 ~[graylog.jar:?] at
~[graylog.jar:?] at
~[graylog.jar:?] at
com.mongodb.internal.connection.ReplyMessage.<init>(ReplyMessage.java:51)
 ~[graylog.jar:?] at
com.mongodb.internal.connection.InternalStreamConnection.getCommandResult(InternalStreamConnection.java:413)
 ~[graylog.jar:?] at
com.mongodb.internal.connection.InternalStreamConnection.receiveCommandMessageResponse(InternalStreamConnection.java:309)
 ~[graylog.jar:?] at
com.mongodb.internal.connection.InternalStreamConnection.sendAndReceive(InternalStreamConnection.java:259)
 ~[graylog.jar:?] at
com.mongodb.internal.connection.UsageTrackingInternalConnection.sendAndReceive(UsageTrackingInternalConnection.java:99)
 ~[graylog.jar:?] at
com.mongodb.internal.connection.DefaultConnectionPool$PooledConnection.sendAndReceive(DefaultConnectionPool.java:450)
 ~[graylog.jar:?] at
com.mongodb.internal.connection.CommandProtocolImpl.execute(CommandProtocolImpl.java:72)
 ~[graylog.jar:?] at
com.mongodb.internal.connection.DefaultServer$DefaultServerProtocolExecutor.execute(DefaultServer.java:226)
 ~[graylog.jar:?] at
com.mongodb.internal.connection.DefaultServerConnection.executeProtocol(DefaultServerConnection.java:269)
 ~[graylog.jar:?] at
com.mongodb.internal.connection.DefaultServerConnection.command(DefaultServerConnection.java:131)
 ~[graylog.jar:?] at
com.mongodb.internal.connection.DefaultServerConnection.command(DefaultServerConnection.java:123)
 ~[graylog.jar:?] at
com.mongodb.operation.CommandOperationHelper.executeCommand(CommandOperationHelper.java:343)
 ~[graylog.jar:?] at
com.mongodb.operation.CommandOperationHelper.executeCommand(CommandOperationHelper.java:334)
 ~[graylog.jar:?] at
com.mongodb.operation.CommandOperationHelper.executeCommandWithConnection(CommandOperationHelper.java:220)
 ~[graylog.jar:?] at
com.mongodb.operation.FindOperation$1.call(FindOperation.java:731)
~[graylog.jar:?] at
com.mongodb.operation.FindOperation$1.call(FindOperation.java:725)
~[graylog.jar:?] at
com.mongodb.operation.OperationHelper.withReadConnectionSource(OperationHelper.java:463)
 ~[graylog.jar:?] at
com.mongodb.operation.FindOperation.execute(FindOperation.java:725)
~[graylog.jar:?] at
com.mongodb.operation.FindOperation.execute(FindOperation.java:89)
~[graylog.jar:?] at
com.mongodb.client.internal.MongoClientDelegate$DelegateOperationExecutor.execute(MongoClientDelegate.java:196)
 ~[graylog.jar:?] at
com.mongodb.client.internal.MongoClientDelegate$DelegateOperationExecutor.execute(MongoClientDelegate.java:177)
 ~[graylog.jar:?] at
com.mongodb.DBCursor.initializeCursor(DBCursor.java:989)
~[graylog.jar:?] at com.mongodb.DBCursor.hasNext(DBCursor.java:172)
~[graylog.jar:?] at org.mongojack.DBCursor.hasNext(DBCursor.java:330)
~[graylog.jar:?] at
org.mongojack.JacksonDBCollection.findOne(JacksonDBCollection.java:1386)
 ~[graylog.jar:?] at
org.mongojack.JacksonDBCollection.findOne(JacksonDBCollection.java:1356)
 ~[graylog.jar:?] at
org.mongojack.JacksonDBCollection.findOneById(JacksonDBCollection.java:1304)
 ~[graylog.jar:?] at
org.mongojack.JacksonDBCollection.findOneById(JacksonDBCollection.java:1291)
 ~[graylog.jar:?] at
org.graylog.plugins.views.search.db.SearchDbService.get(SearchDbService.java:65)
 ~[graylog.jar:?] at
org.graylog.plugins.views.search.views.RequiresParameterSupport.test(RequiresParameterSupport.java:43)
 ~[graylog.jar:?] at
org.graylog.plugins.views.search.views.RequiresParameterSupport.test(RequiresParameterSupport.java:31)
 ~[graylog.jar:?] at
org.graylog.plugins.views.Requirements.lambda$new$0(Requirements.java:39)
 ~[graylog.jar:?] at
java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193)
 ~[?:1.8.0_342] at
java.util.Iterator.forEachRemaining(Iterator.java:116) ~[?:1.8.0_342] at
java.util.Spliterators$IteratorSpliterator.forEachRemaining(Spliterators.java:1801)
 ~[?:1.8.0_342] at
java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:482)
~[?:1.8.0_342] at
java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:472)
 ~[?:1.8.0_342] at
java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708)
 ~[?:1.8.0_342] at
java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
~[?:1.8.0_342] at
java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:566)
~[?:1.8.0_342] at
org.graylog.plugins.views.Requirements.<init>(Requirements.java:41)
 ~[graylog.jar:?] at
org.graylog.plugins.views.search.views.ViewRequirements.<init>(ViewRequirements.java:31)
 ~[graylog.jar:?] at
org.graylog.plugins.views.search.views.ViewRequirements$FastClassByGuice$97cefd36.newInstance(<generated>)
 ~[graylog.jar:?] at
com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:89)
 ~[graylog.jar:?] at
com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114)
 ~[graylog.jar:?] at
com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:91)
 ~[graylog.jar:?] at
com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:306)
 ~[graylog.jar:?] at
com.google.inject.internal.InjectorImpl$1.get(InjectorImpl.java:1050)
~[graylog.jar:?] at
com.google.inject.assistedinject.FactoryProvider2.invoke(FactoryProvider2.java:836)
 ~[graylog.jar:?] at com.sun.proxy.$Proxy127.create(Unknown Source)
~[?:?] at
org.graylog.plugins.views.search.views.ViewService.requirementsForView(ViewService.java:196)
 ~[graylog.jar:?] at
 ~[?:1.8.0_342] at
 ~[?:1.8.0_342] at
~[?:1.8.0_342] at
 ~[?:1.8.0_342] at
java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150)
 ~[?:1.8.0_342] at
java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173)
 ~[?:1.8.0_342] at
~[?:1.8.0_342] at
java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:485)
~[?:1.8.0_342] at
org.graylog2.migrations.V20200803120800_GrantsMigrations.ViewOwnerShipToGrantsMigration.upgrade(ViewOwnerShipToGrantsMigration.java:58)
 ~[graylog.jar:?] at
org.graylog2.migrations.V20200803120800_GrantsMigrations.GrantsMetaMigration.upgrade(GrantsMetaMigration.java:113)
 ~[graylog.jar:?] at
org.graylog2.periodical.ConfigurationManagementPeriodical.doRun(ConfigurationManagementPeriodical.java:42)
 [graylog.jar:?] at
org.graylog2.plugin.periodical.Periodical.run(Periodical.java:77)
[graylog.jar:?] at java.lang.Thread.run(Thread.java:750) [?:1.8.0_342]
Caused by:
com.fasterxml.jackson.databind.exc.InvalidDefinitionException: Cannot
construct instance of`org.graylog.plugins.views.search.searchtypes.pivot.buckets.TimeUnitInterval$Builder`,
 problem: Time unit must be {quantity}{unit}, where quantity is a
positive number and unit [smhdwM]. at [Source:
de.undercouch.bson4jackson.io.LittleEndianInputStream@5ef3855e; pos:
1088] (through reference chain:
org.graylog.plugins.views.search.AutoValue_Search$Builder["queries"]->org.graylog.plugins.views.search.AutoValue_Query$Builder["search_types"]->java.util.HashSet[1]->org.graylog.plugins.views.search.searchtypes.pivot.AutoValue_Pivot$Builder["row_groups"]->java.util.ArrayList[0]->org.graylog.plugins.views.search.searchtypes.pivot.buckets.AutoValue_Time$Builder["interval"])
 at
com.fasterxml.jackson.databind.exc.InvalidDefinitionException.from(InvalidDefinitionException.java:67)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.DeserializationContext.instantiationException(DeserializationContext.java:1608)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.DeserializationContext.handleInstantiationProblem(DeserializationContext.java:1073)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.BeanDeserializerBase.wrapInstantiationProblem(BeanDeserializerBase.java:1754)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.finishBuild(BuilderBasedDeserializer.java:178)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.deserialize(BuilderBasedDeserializer.java:216)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.jsontype.impl.AsPropertyTypeDeserializer._deserializeTypedForId(AsPropertyTypeDeserializer.java:130)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.jsontype.impl.AsPropertyTypeDeserializer.deserializeTypedFromObject(AsPropertyTypeDeserializer.java:97)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.AbstractDeserializer.deserializeWithType(AbstractDeserializer.java:254)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.impl.MethodProperty.deserializeSetAndReturn(MethodProperty.java:167)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.deserializeFromObject(BuilderBasedDeserializer.java:314)
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:288)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:245)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:27)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.impl.MethodProperty.deserializeSetAndReturn(MethodProperty.java:158)
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.vanillaDeserialize(BuilderBasedDeserializer.java:269)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.deserialize(BuilderBasedDeserializer.java:193)
 ~[graylog.jar:?] at
com.fasterxml.jackson.datatype.guava.deser.GuavaImmutableCollectionDeserializer._deserializeContents(GuavaImmutableCollectionDeserializer.java:42)
 ~[graylog.jar:?] at
com.fasterxml.jackson.datatype.guava.deser.GuavaImmutableCollectionDeserializer._deserializeContents(GuavaImmutableCollectionDeserializer.java:14)
 ~[graylog.jar:?] at
com.fasterxml.jackson.datatype.guava.deser.GuavaCollectionDeserializer.deserialize(GuavaCollectionDeserializer.java:104)
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.ObjectMapper._readValue(ObjectMapper.java:3985)
 ~[graylog.jar:?] at
com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:2343)
 ~[graylog.jar:?] at
org.mongojack.internal.stream.JacksonDBDecoder.decode(JacksonDBDecoder.java:80)
 ~[graylog.jar:?] at
org.mongojack.internal.stream.JacksonDBDecoder.decode(JacksonDBDecoder.java:64)
 ~[graylog.jar:?] ... 76 more Caused by:
java.lang.IllegalArgumentException: Time unit must be {quantity}{unit},
where quantity is a positive number and unit [smhdwM]. at
com.google.common.base.Preconditions.checkArgument(Preconditions.java:142)
 ~[graylog.jar:?] at
org.graylog.plugins.views.search.searchtypes.pivot.buckets.TimeUnitInterval$Builder.build(TimeUnitInterval.java:79)
 ~[graylog.jar:?] at
sun.reflect.GeneratedMethodAccessor147.invoke(Unknown Source) ~[?:?] at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
 ~[?:1.8.0_342] at java.lang.reflect.Method.invoke(Method.java:498)
~[?:1.8.0_342] at
com.fasterxml.jackson.databind.deser.BuilderBasedDeserializer.finishBuild(BuilderBasedDeserializer.java:176)
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] at
 ~[graylog.jar:?] ... 76 more `
I can’t find problematic entry in MongoDB, how should I proceed to track it down?
My environment:
  • Graylog Version: 4.0.17-1
  • Java Version: openjdk version “1.8.0_342”
  • Elasticsearch Version: 6.8.23
  • MongoDB Version: 4.2.22
  • Operating System: Ubuntu 18.04.6 LTS
Hello @IdahoPL
By chance are all you plugin the same version ( i.e., updated 4.0.17)?
EDIT: since that was a long upgrade, I also did this while back, ensure you have the correct graylog.conf file, things have changed. If all that is set you could check Mongo.
root#  mongo
mongo > use graylog
mongo > db.adminCommand( { getParameter: 1, featureCompatibilityVersion: 1 } )
NOTE: The above command should show the same version that is installed.
If the out put shows Less then the version installed, execute the following command (i.e mongodb3.4 is install)
Execute the following commnad in mongo shell.
mongo >>  db.adminCommand( { setFeatureCompatibilityVersion: "3.4" } )
EDIT2: I remember, some issues with GL 4.0 I think we upgrade to 4.1 fix those issues.
EDIT3: Adding on, I did find this in GitHub, maybe it will help.
Thank you for your answer.
All plugins in /usr/share/graylog-server/plugin have 4.0.17 in file names, I don’t use external plugins.
graylog.conf was updated with every Graylog upgrade, diff from default config show only needed adjustments.
I’m using MongoDB 4.2, featureCompatibilityVersion is 4.2, I’ve adjusted it on every MongoDB upgrade since it was introduced (3.4 IIRC).
rs0:PRIMARY> use graylog2
switched to db graylog2
rs0:PRIMARY> db.adminCommand( { getParameter: 1, featureCompatibilityVersion: 1 } )
        "featureCompatibilityVersion" : {
                "version" : "4.2"
        "ok" : 1,
        "$clusterTime" : {
                "clusterTime" : Timestamp(1664614367, 5),
                "signature" : {
                        "hash" : BinData(0,"k6NwDKrCwK3GHkbz9cqVPph+GMI="),
                        "keyId" : NumberLong("7148369247624757250")
        "operationTime" : Timestamp(1664614367, 5)
I’m afraid to upgrade to 4.1 with 4.0 not fully upgraded. It seems that somwhere there is some interval set without time unit or something similar. I just can’t find it.
I’ve cleared one by one (and later restored) those collections in MongoDB:
  • alerts
  • dashboards
  • dead_letters
  • event_definitions
  • streamrules
  • streams
and restarted Graylog after clearing single one of them. Migration still failed, so I’ve restored cleared collection and move to another.
