Elasticsearch error
hello, i got some issues in elasticsearch.
when i curl -xget 'http://localhost:9200/_cluster/health?pretty=true'
i got error:
curl: (7) Failed to connect to localhost port 9200: Connection refused
then i check my elasticsearch’s status:
root@stagging-graylog:~$ sudo systemctl status elasticsearch
● elasticsearch.service - Elasticsearch
   Loaded: loaded (/usr/lib/systemd/system/elasticsearch.service; enabled; vendoem/elasticsearch.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2018-03-20 10:32:10 WIB; 53min a
     Docs: http://www.elastic.co
  Process: 9365 ExecStart=/usr/share/elasticsearch/bin/elasticsearch -Des.pidfile=${PID_DIR}/elasticsearch.pid -Des.default.path.home=${ES_HOME} -Des.default.pault.path.home=${ES_HOME} -Des.default.path.logs=${LOG_DIR} -Des.default.path.data=${DATA_DIR} -Des.default.path.conf=${CONF_DIR} (code=exited, status=1/FAILURE)
  Process: 9362 ExecStartPre=/usr/share/elasticsearch/bin/elasticsearch-systemd-elasticsearch/bin/elasticsearch-systemd-pre-exec (code=exited, status=0/SUCCESS)
 Main PID: 9365 (code=exited, status=1/FAILURE)
Mar 20 10:32:10 stagging-graylog elasticsearch[9365]:
Mar 20 10:32:10 stagging-graylog elasticsearch[9365]: #
Mar 20 10:32:10 stagging-graylog elasticsearch[9365]: # ------------------------
Mar 20 10:32:10 stagging-graylog elasticsearch[9365]: # Block initial recovery a
Mar 20 10:32:10 stagging-graylog systemd[1]: elasticsearch.service: Main process[1]: elasticsearch.service: Main process exited, code=exited, status=1/FAILURE
Mar 20 10:32:10 stagging-graylogsystemd[1]: elasticsearch.service: Unit entered[1]: elasticsearch.service: Unit entered failed state.
Mar 20 10:32:10 stagging-graylog systemd[1]: elasticsearch.service: Failed with[1]: elasticsearch.service: Failed with result 'exit-code'.
here the logs:
[2018-03-20 10:15:45,543][INFO ][node                     ] [Schemer] version[2.4.6], pid[8225], build[5376dca/2017-07-18T12:17:44Z]
[2018-03-20 10:15:45,546][INFO ][node                     ] [Schemer] initializializing ...
[2018-03-20 10:15:45,979][INFO ][plugins                  ] [Schemer] modules [reindex, lang-expression, lang-groovy], plugins [], sites []
[2018-03-20 10:15:46,005][INFO ][env                      ] [Schemer] using [1] data paths, mounts [[//dev/vda1)]], net usable_space [21.5gb], net total_space [28.4gb], spins? [possibly], types [ext4]
[2018-03-20 10:15:46,005][INFO ][env                      ] [Schemer] heap size [1015.6mb], compressed ordinary object pointers [true]
[2018-03-20 10:15:46,017][ERROR][bootstrap                ] Exception
java.lang.Error: java.security.AccessControlException: access denied ("java.lang.reflect.ReflectPermission" "suppressAccessChecks")
        at com.twitter.jsr166e.Striped64.<clinit>(Striped64.java:319)
 at org.elasticsearch.common.metrics.CounterMetric.<init>(CounterMetretric.java:28)
 at org.elasticsearch.common.util.concurrent.EsAbortPolicy.<init>(EsAborPolicy.java:30)
 at org.elasticsearch.common.util.concurrent.EsExecutors.newFixed(EsExectors.java:80)
 at org.elasticsearch.threadpool.ThreadPool.rebuild(ThreadPool.java:510)
 at org.elasticsearch.threadpool.ThreadPool.build(ThreadPool.java:428)
at org.elasticsearch.threadpool.ThreadPool.<init>(ThreadPool.java:234)
        at org.elasticsearch.node.Node.<init>(Node.java:170)
        at org.elasticsearch.node.Node.<init>(Node.java:140)
        at org.elasticsearch.node.NodeBuilder.build(NodeBuilder.java:143)
        at org.elasticsearch.bootstrap.Bootstrap.setup(Bootstrap.java:194)
        at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:286)
Which version of Java are you using?
https://github.com/elastic/elasticsearch/issues/18761
mine is (build 9-internal+0-2016-04-14-195246.buildd.src)
Elasticsearch 2.x and Graylog 2.x don’t work with Java 9. You’ll have to downgrade to Java 8.
