Elasticsearch cluster unhealthy (RED) (triggered a year ago)
I am using the Graylog 2.4.5+8e18e6a on srv-syslog (Oracle Corporation 1.8.0_171 on Linux 3.10.0-862.3.2.el7.x86_64).
# curl -XGET http://localhost:9200/_cluster/health?pretty
  "cluster_name" : "graylog2",
  "status" : "green",
  "timed_out" : false,
  "number_of_nodes" : 1,
  "number_of_data_nodes" : 1,
  "active_primary_shards" : 12,
  "active_shards" : 12,
  "relocating_shards" : 0,
  "initializing_shards" : 0,
  "unassigned_shards" : 0,
  "active_shards_percent_as_number" : 100.0
# curl -XGET http://localhost:9200/_cat/shards
graylog2_39 2 p STARTED 499431   166mb 127.0.0.1 Larry Bodine
graylog2_39 1 p STARTED 499428 166.2mb 127.0.0.1 Larry Bodine
graylog2_39 3 p STARTED 501379 166.4mb 127.0.0.1 Larry Bodine
graylog2_39 0 p STARTED 499782 166.4mb 127.0.0.1 Larry Bodine
graylog2_41 2 p STARTED 219523  69.5mb 127.0.0.1 Larry Bodine
graylog2_41 1 p STARTED 219553  69.6mb 127.0.0.1 Larry Bodine
graylog2_41 3 p STARTED 219303    71mb 127.0.0.1 Larry Bodine
graylog2_41 0 p STARTED 219113  69.3mb 127.0.0.1 Larry Bodine
graylog2_40 2 p STARTED 500417 153.4mb 127.0.0.1 Larry Bodine
graylog2_40 1 p STARTED 500206 153.1mb 127.0.0.1 Larry Bodine
graylog2_40 3 p STARTED 500506   153mb 127.0.0.1 Larry Bodine
graylog2_40 0 p STARTED 499053 152.8mb 127.0.0.1 Larry Bodine
  "name" : "Larry Bodine",
  "cluster_uuid" : "TcSg5UwGQtKjTtImCTQZng",
  "version" : {
    "number" : "2.4.6",
    "build_hash" : "5376dca9f70f3abef96a77f4bb22720ace8240fd",
    "build_timestamp" : "2017-07-18T12:17:44Z",
    "build_snapshot" : false,
    "lucene_version" : "5.5.4"
  "tagline" : "You Know, for Search"
In webinterface (Graylog/System/Overview) i have a massage:
The Elasticsearch cluster state is RED which means shards are unassigned. This usually indicates a crashed and corrupt cluster and needs to be investigated. Graylog will write into the local disk journal.
What do I need to do to clear the warning?
“Triggered a year ago”. :wink:
You can click on the ‘X’ in the upper right corner of the notification to clear it.
Thank you so much. I understand that the indexes are in working order, but I could not cope with the warning. :smile:
