I’ve just installed the first graylog-instance.
I’m ingesting Squid-Proxy-Logs - one UDP-Syslog Input is defined and used by 2 Proxys. an Extractor is connected to the input, I’ve defined 2 Streams to seperate each Proxy-Log in it’s own index.
Everything works as intended - except that each message is stored twice. One copy contains the original (raw) incoming message, the second one has the extracted fields. The only other difference is the graylog-timestamp and the ID (both are stored in the same index), the raw message is stored about 1 sec before the extracted one.
So the message is not sent twice, it has been removed from the all_messages index and is stored two times in the same index.
I’d like to get rid of the original message, can somebody shed some light on that problem ?
Thank you
