Drop few words from Logs
I have already implemented pipeline to drop message which contains specific words but I am looking for some example or help that how can I drop words from incoming log.
Let say I want to remove “I want to” from message “This is the word I want to delete and more words” and
I want to get only “This is the word delete and more words”
I want to keep my message that comes from FortiGate and I am interested in Src IP , Dst IP, Type of service or protocol, policy action if its allowed or denied and dont want to keep duration, sequence number and those kinds of information.
Will this help in reducing the size of daily logs as well?
  • OS Information:
    Ubuntu 18.04
  • Package Version:
    4.1
If you want to drop fields from a message coming in before it is stored you can use remove_field() if you are looking to remove words from a string you can use replace() and just replace the string portion with something like this:
set_field(to_string($message.some_field), replace(to_string($message.some_field), "I want to", ""));
depending on the volume it may or may not help reduce your message load.
Hello
Just a suggestion. You should be able to configure FortiGate depending on your model/version to prevent certain logs form being sent. This may help reduce the amount of log/s being ingested.
Not sure what Model/Version you have so here are a couple link for you.
https://docs.fortinet.com/document/fortimail/7.0.0/cli-reference/820362/log-setting-remote
https://help.fortinet.com/fos40hlp/41/wwhelp/wwhimpl/common/html/wwhelp.htm?context=fgt&file=Logging.35.6.html
https://docs.fortinet.com/document/fortigate/7.0.1/administration-guide/557920/override-fortianalyzer-and-syslog-server-settings
https://docs.fortinet.com/document/fortigate/7.0.2/cli-reference/456620/config-log-syslogd-setting
Hope that helps
I will try this.
Mark as the answer if it works for future searches! :smiley:
Does this make sense?
I have few words in log like vd=“root” and I want to remove this.
rule “function Fortigate Fields”
has_field(“vd=root”)
remove_field(“vd=root”);
I tried this and it didn’t work.
I want to store these fields from my FortiGate log.
I want to store similar kind of data.
Like
srcip
srcintf
srcintfrole
dstip
dstintf
dstintfrole
action
policyid=
policytype
dstcountry
Is it a field name of “vd=root” or is it that the “vd” field contains the data “root”. I don’t think you can have an ‘=’ in a field name so it must be the latter? in which case your rule would look more like this: (Note: I am using the forum formatting tool </> to make the code look readable…)
rule "function remove Fortigate Fields"
    $message.vd == "root"
    remove_field("vd");
I have the whole message from Fortigate and its stated in the log its like vd=“root” its basically virtual domain = root.
https://docs.fortinet.com/document/fortigate/6.2.3/fortios-log-message-reference/357866/log-message-fields
In the above link you can see vd=“vdom1”
date=2017-11-15 time=11:44:16 logid=“0000000013” type=“traffic” subtype=“forward” level=“notice” vd="vdom1" eventtime=1510775056
Thought so - so assuming you have broken out the message into it’s respective fields, it would be utilizing remove_field("vd");
I have a few FortiGate firewalls sending logs. I created a INPUT Rawplain/Text. Then I created couple
of extractors that I need.
Here is an example of extracting the srcip from my logs and noticed I use the “Cut” tic box instead of copy.
This is the results, plus you can see the other fields I have extracted from the message.
I try to keep the amount of fields low to save disk space so I only selected a few extractors that I needed.
Here is a list some regex. You can test these on your INPUT to see if they work for you. Just a reminder I’m using Raw/Plaintext UDP I just started learning regex on Graylog so these may be a little sloppy.
SourceIP (srcip)
srcip=+?((?:\d+\.){3}\d+).+
Destination Interface  (dstinif)
dstintf="(.*?)\"
SourcePort (srcport)
srcport=(\d+)
Destination IP (dstip)
dstip=+?((?:\d+\.){3}\d+).+
PolicyID (policyid)
policyid=(\d+)
Action  (action)
action="(.*?)"
Hope that helps
Thanks gsmith.
I already have extractors if I go to FortiGate Input → Extractor.
My confusion is how I can attach them that I can only see the fields I want in my logs and it will delete the other stuff in FortiGate Traffic stream.
I understand now. Understanding your setup the only way I know of at this point would be what @tmacgbay suggested by using a pipeline/s. Sorry I cant be more help.
I tried it but didnt work. I can still see vd=root in the messages.
There is no way to get log like below?
What did you try? It is still not clear what you have and what you want to do with it. Can you give an obfuscated and nicely formatted (using the forum tool </>) real example of:
  • The message you want to modify
  • The fields that message has been broken out into
  • What you want the results to look like
If you set your extractors to NOT leave the original message intact and only extract what you want, I think you would end up with only those fields and a leftover messy $message.message that you could then modify into something you want. @gsmith would confirm it could work that way… :slight_smile:
I have tried this and then attached it to my FortiGate Traffic stream.
rule “function remove Fortigate Fields”
has_field(“devname”)
remove_field(“vd”);
Is there any other way that I can achieve this?
I have nothing to work with until you answer/post based on my previous post…
I tried this in the pipeline but still I can see vd in the logs and also devid.
remove_field(“vd”);
and Also
set_field(to_string($message.some_field), replace(to_string($message.some_field), “devid=”, “”));
