Does not save new indexes,
Hello .I have a request and I need help.My settings
Total: 164 indices, 11,753,813,594 documents, 2.0TiB
Index prefix:graylog
Shards:4
Replicas:0
Field type refresh interval:5 seconds
Index rotation strategy:Index Size
Max index size:21474836480 bytes (20.0GiB)
Index retention strategy:Delete
Max number of indices:240
Why doesn’t it create new indexes, as if it stops 109 ?
ubuntu
df -Th
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 16G 0 16G 0% /dev
tmpfs tmpfs 3,2G 1,3M 3,2G 1% /run
/dev/mapper/ubuntu–vg-ubuntu–lv ext4 6,9T 2,0T 4,6T 31% /
saves to level 2TiB and end
Can someone help why? How to increase 2TiB to 6.9 TiB
Best Regards.
Pablo
Can you clarify what “does not save new indexes” mean?
What indexer are you using, Elasticsearch or OpenSearch? And what version?
Are you running both Graylog and the Indexer (Elasticsearch or OpenSearch) all on one server?
