Docker Graylog unhealthy
Dear community,
I got to know Graylog at work. Recently, I was able to get my hands on an old HP Elitedesk 800 G2, which I want to use as a little server in our basement. I installed Ubuntu Server and Docker environment.
My first project ist “Graylog”. After 2 nights of try and error, I got it finaly to the login page of Graylog.
Unfortunatley, graylog is not reachable anymore. The container indicates a status of “unhealthy”. I am a newbee with Docker, so I am not very sure on how to debug this. Any ideas are very much welcome.
  • OS Information: Ubuntu 22.04.1 LTS
    Here is my docker-compose.yml:
version: '2'
services:
  mongodb:
    image: mongo:5.0.13
    networks:
      - graylog
  #DB in share for persistence
    volumes:
      - mongo_data:/data/db
   # Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/7.10/docker.html
  elasticsearch:
    image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
    #data folder in share for persistence
    volumes:
    environment:
      - http.host=0.0.0.0
      - transport.host=localhost
      - network.host=0.0.0.0
    ulimits:
      memlock:
        soft: -1
        hard: -1
    mem_limit: 1g
    networks:
      - graylog
  graylog:
    image: graylog/graylog:5.0
    #journal and config directories in local NFS share for persistence
    volumes:
    environment:
      - GRAYLOG_PASSWORD_SECRET=[abcd]
      # Password: admin
      - GRAYLOG_ROOT_PASSWORD_SHA2=[efgh]
      - GRAYLOG_HTTP_EXTERNAL_URI=http://192.168.1.57:9000/
      - GRAYLOG_HTTP_ENABLE_CORS=true
    entrypoint: /usr/bin/tini -- wait-for-it elasticsearch:9200 --  /docker-entrypoint.sh
    networks:
      - graylog
    links:
      - mongodb:mongo
      - elasticsearch
    restart: always
    depends_on:
      - mongodb
      - elasticsearch
    ports:
      - 9000:9000
      # Syslog TCP
      - 1514:1514
      # Syslog UDP
      - 1514:1514/udp
      # GELF TCP
      - 12201:12201
      # GELF UDP
      - 12201:12201/udp
# Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
volumes:
  mongo_data:
    driver: local
  es_data:
    driver: local
  graylog_journal:
    driver: local
networks:
    graylog:
      driver: bridge
I took the basics from the docker-docs and enhanced it with some things I found on the internet. I have to admit that I do not understand all of it.
State of the container:
user@ubuntu:~$ docker ps
CONTAINER ID   IMAGE                 COMMAND                  CREATED        STATUS                      PORTS        NAMES
694aa8348e37   graylog/graylog:5.0   "/usr/bin/tini -- wa…"   36 hours ago   Up 10 minutes (unhealthy)   0.0.0.0:1514->1514/tcp, :::1514->1514/tcp, 0.0.0.0:9000->9000/tcp, 0.0.0.0:1514->1514/udp, :::9000->9000/tcp, :::1514->1514/udp, 0.0.0.0:12201->12201/tcp, 0.0.0.0:12201->12201/udp, :::12201->12201/tcp, :::12201->12201/udp   graylog_graylog_1
Well, I deleted the container and re-created it with docker-compose up -d. If I remember right, the container took some minutes to start and after a while, I could access Graylog. After turning of the computer yesterday and starting it up today, the container shows unhealthy.
Perhaps, someone can help with debugging this:
  • What is a normal startup-time, until a Docker Container is accessable?
  • What am I doing wrong? Why is my Graylog unhealthy?
  • Is there something wrong with my docker-compose.yml?
EDIT:
At the moment, the network is in “bridge”-mode. I do have a Unifi-network at home and I would like to test the macvlan-option. Is this relevant in debugging this? Should I first get a healthy Graylog and then start trying the macvlan-option or is this independent from each other?
I just figured out, how to tail the logs for a container. There seems to be something with my mongo-db:
2022-12-18 19:33:29,866 INFO : org.graylog2.featureflag.ImmutableFeatureFlagsCollector - Following feature flags are used: {default properties file=[scripting_api_preview=off, search_filter=on]}
2022-12-18 19:33:30,336 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: AWS plugins 5.0.1 [org.graylog.aws.AWSPlugin]
2022-12-18 19:33:30,337 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Integrations 5.0.1 [org.graylog.integrations.IntegrationsPlugin]
2022-12-18 19:33:30,338 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Collector 5.0.1 [org.graylog.plugins.collector.CollectorPlugin]
2022-12-18 19:33:30,338 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Threat Intelligence Plugin 5.0.1 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2022-12-18 19:33:30,338 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Elasticsearch 7 Support 5.0.1+f28b729 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2022-12-18 19:33:30,338 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: OpenSearch 2 Support 5.0.1+f28b729 [org.graylog.storage.opensearch2.OpenSearch2Plugin]
2022-12-18 19:33:30,357 INFO : org.graylog2.bootstrap.CmdLineTool - Running with JVM arguments: -Dlog4j2.formatMsgNoLookups=true -Djdk.tls.acknowledgeCloseNotify=true -XX:+UnlockExperimentalVMOptions -XX:-OmitStackTraceInFastThrow -XX:+UseG1GC -Dlog4j.configurationFile=/usr/share/graylog/data/config/log4j2.xml -Djava.library.path=/usr/share/graylog/lib/sigar/ -Dgraylog2.installation_source=docker
2022-12-18 19:33:30,492 INFO : org.mongodb.driver.client - MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "4.7.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "5.15.0-56-generic"}, "platform": "Java/Eclipse Adoptium/17.0.5+8"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@7a389761]}, clusterSettings={hosts=[mongo:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='30000 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
2022-12-18 19:33:30,493 INFO : org.mongodb.driver.client - MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "4.7.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "5.15.0-56-generic"}, "platform": "Java/Eclipse Adoptium/17.0.5+8"} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, streamFactoryFactory=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, EnumCodecProvider{}, com.mongodb.Jep395RecordCodecProvider@7a389761]}, clusterSettings={hosts=[mongo:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='30000 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, sendBufferSize=0}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, sendBufferSize=0}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, contextProvider=null}
2022-12-18 19:33:30,500 INFO : org.mongodb.driver.cluster - Cluster description not yet available. Waiting for 30000 ms before timing out
2022-12-18 19:33:30,506 INFO : org.mongodb.driver.cluster - Exception in monitor thread while connecting to server mongo:27017
com.mongodb.MongoSocketException: mongo
        at com.mongodb.ServerAddress.getSocketAddresses(ServerAddress.java:217) ~[graylog.jar:?]
        at com.mongodb.internal.connection.SocketStream.initializeSocket(SocketStream.java:75) ~[graylog.jar:?]
        at com.mongodb.internal.connection.SocketStream.open(SocketStream.java:65) ~[graylog.jar:?]
        at com.mongodb.internal.connection.InternalStreamConnection.open(InternalStreamConnection.java:180) ~[graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitorRunnable.lookupServerDescription(DefaultServerMonitor.java:193) [graylog.jar:?]
        at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitorRunnable.run(DefaultServerMonitor.java:157) [graylog.jar:?]
        at java.lang.Thread.run(Unknown Source) [?:?]
Caused by: java.net.UnknownHostException: mongo
        at java.net.InetAddress$CachedAddresses.get(Unknown Source) ~[?:?]
        at java.net.InetAddress$NameServiceAddresses.get(Unknown Source) ~[?:?]
        at java.net.InetAddress.getAllByName0(Unknown Source) ~[?:?]
        at java.net.InetAddress.getAllByName(Unknown Source) ~[?:?]
        at com.mongodb.ServerAddress.getSocketAddresses(ServerAddress.java:209) ~[graylog.jar:?]
        ... 6 more
2022-12-18 19:34:00,502 INFO : org.graylog2.bootstrap.preflight.MongoDBPreflightCheck - MongoDB is not available. Retry #1
2022-12-18 19:34:02,503 INFO : org.mongodb.driver.cluster - Cluster description not yet available. Waiting for 30000 ms before timing out
2022-12-18 19:34:32,504 INFO : org.graylog2.bootstrap.preflight.MongoDBPreflightCheck - MongoDB is not available. Retry #2
2022-12-18 19:34:34,505 INFO : org.mongodb.driver.cluster - Cluster description not yet available. Waiting for 30000 ms before timing out
2022-12-18 19:35:04,506 INFO : org.graylog2.bootstrap.preflight.MongoDBPreflightCheck - MongoDB is not available. Retry #3
2022-12-18 19:35:06,507 INFO : org.mongodb.driver.cluster - Cluster description not yet available. Waiting for 30000 ms before timing out
2022-12-18 19:35:36,507 INFO : org.graylog2.bootstrap.preflight.MongoDBPreflightCheck - MongoDB is not available. Retry #4
2022-12-18 19:35:38,508 INFO : org.mongodb.driver.cluster - Cluster description not yet available. Waiting for 30000 ms before timing out
2022-12-18 19:36:08,509 INFO : org.graylog2.bootstrap.preflight.MongoDBPreflightCheck - MongoDB is not available. Retry #5
2022-12-18 19:36:10,510 INFO : org.mongodb.driver.cluster - Cluster description not yet available. Waiting for 30000 ms before timing out
2022-12-18 19:36:40,510 INFO : org.graylog2.bootstrap.preflight.MongoDBPreflightCheck - MongoDB is not available. Retry #6
2022-12-18 19:36:42,511 INFO : org.mongodb.driver.cluster - Cluster description not yet available. Waiting for 30000 ms before timing out
2022-12-18 19:37:12,512 INFO : org.graylog2.bootstrap.preflight.MongoDBPreflightCheck - MongoDB is not available. Retry #7
2022-12-18 19:37:14,512 INFO : org.mongodb.driver.cluster - Cluster description not yet available. Waiting for 30000 ms before timing out
What does this mean?
Sadly, I never worked with Docker and Graylog. I know from my coworker he had issues with restarting the container.
Once he restarted his host, the container didn’t restart, so he had to do it manually.
Maybe you can try to restart mongo manually and then graylog after it?
Hit @StefanAustin,
thank you very much for your reply. Well, I just hit docker-compose up -d et voilà, the login screen is available.
Am I right, that the graylog-container started with the boot of my ubuntu, but the mongo-db did not? How do I configre a auto-boot for mongo-DB and Elasticsearch?
user@ubuntu:~/Docker/Graylog$ docker ps
694aa8348e37   graylog/graylog:5.0                                        "/usr/bin/tini -- wa…"   44 hours ago   Up 31 minutes (healthy)   0.0.0.0:1514->1514/tcp, :::1514->1514/tcp, 0.0.0.0:9000->9000/tcp, 0.0.0.0:1514->1514/udp, :::9000->9000/tcp, :::1514->1514/udp, 0.0.0.0:12201->12201/tcp, 0.0.0.0:12201->12201/udp, :::12201->12201/tcp, :::12201->12201/udp   graylog_graylog_1
e4d249073031   mongo:5.0.13                                               "docker-entrypoint.s…"   44 hours ago   Up About a minute         27017/tcp        graylog_mongodb_1
3e2daccf8dfe   docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2   "/tini -- /usr/local…"   44 hours ago   Up About a minute         9200/tcp, 9300/tcp        graylog_elasticsearch_1
Sorry for answering late, but I do not know the answer.
Most likely it is just a single line in a config file, but I never used Docker besides in a home lab to test things.
Hi there,
Can you check and show the values for:
docker ps
Check the id container for “mongodb” and show us the log
docker logs <container ID>
I haven´t still made the Graylog 5.0 work in container smooth.
Check this version of YML also (using opensearch):
https://github.com/Graylog2/docker-compose/blob/main/open-core/docker-compose.yml
Hey @schneich
you have something like this in compose file.
links:
 - mongodb:mongo
 - elasticsearch
 restart: always < ---- here
depends_on:
 - mongodb
 - elasticsearch
You can apply whatever Restart Policy you prefer after the –restart option, so:
–restart on-failure
–restart always
–restart unless-stopped
For mongoDb
 mongo1:
    hostname: mongo1
    container_name: mongo1
    image: 'mongodb/mongodb:latest'
    restart: unless-stopped (i.e., always)
    networks:
Hi @lcosta and @gsmith,
thank you very much for your inputs.
@lcosta: I will try to follow the current path. If I don’t succeed, I will be happy to try it your way.
@gsmith: thank you for pointing out the -restart option. I stumbled across it in the documentation, but did not understand it at the time and I am still not sure:
I would like that Graylog, MongoDB and Elasticsearch starts, as soon as the server is booted. If the container stops with an error, I would like to now, so that I can follow it up. I the container is booted automatically, I might not be aware of errors, which crashes Graylog from time to time - if that happens at all. :slight_smile:
Would you use
-restart: always
or would you use
-restart: unless-stopped
If your container/s stop or have issues, then you would need other software to help you get those alert or notifications. I belive docker has softerware for this purpose.
You could test this out by configuring one of those settings and rebooting the host.
Just for the record, I ended up using this:
So far, no known issues with this configuration.
