Background
I am running Graylog via a docker container as explained int he tutorial:
https://docs.graylog.org/en/3.3/pages/installation/docker.html
$ docker run --name mongo -d mongo:3
$ docker run --name elasticsearch \
-e "http.host=0.0.0.0" \
-e "ES_JAVA_OPTS=-Xms512m -Xmx512m" \
-d docker.elastic.co/elasticsearch/elasticsearch-oss:6.8.10
$ docker run --link mongo --link elasticsearch \
-p 9000:9000 -p 12201:12201 -p 1514:1514 -p 5555:5555 \
-e GRAYLOG_HTTP_EXTERNAL_URI="http://127.0.0.1:9000/" \
-d graylog/graylog:3.3
However, now I need to start clean with fresh data. I don’t want to loose all my configurations and extractors, so the minimal change I need is to simply delete all messages.
Index time
After some research I see that Graylog does not support deleting individual messages, the smallest unit it understands is an index.
So I need to delete all indexes from GayLog.
After some more research, I found the delete API in elasticsearch, and I tried this command (but it fails):
$ curl -XDELETE 'http://localhost:9000/*'
{"type":"ApiError","message":"HTTP 404 Not Found"}
I use localhost:9000 because that is the port I use to access graylog.
Questions
- What am I dong wrong (how can I fix this command so it works as intended)?
- Is there an easier way to delete all messages in Graylog?
