Data Adapter for Emerging threats IP List
What would be the most efficient way to pull in a IP List from a URL without having two column’s or csv/dsv format?
I’d like to pull in https://rules.emergingthreats.net/fwrules/emerging-Block-IPs.txt
He @ion-storm
the main problem with that list is that it is not “clean” - currently Graylog is very strict. No duplicated entries are allowed in DSV, no additional spaces between the lines.
So in general you could just check in a list like ( https://rules.emergingthreats.net/blockrules/compromised-ips.txt ) just the existence of one IP. But as your list included spaces, comments and dupl. content it would need to be cleaned before you can use it with Graylog.
One other option (for the long run) would be to create a feature issue that the DSV Lookup Table is a little more relaxed (or can be configured to be) over at github: https://github.com/Graylog2/graylog2-server/issues
