Hi, I working on creating a line chart to represent the cumulative sum of a field grouped by timestamps, let’s say for example the field represents the total count of the newly connected users.
Example:
msg1 = { “users”: 2 }
cumulative sum = 2.
msg2 = { “users”: 3 }
cumulative sum = 2 + 3 = 5.
When creating a line chart I want to represent cumulative sum / timestamps. How would I achieve that? would I be able to use pipelines?
Thank you for your question. To help you get a community response quicker, I’ve moved it to Daily Challenges. Always consider that input or output visuals often attract responses.
While you await a community response, check out these links and let me know if they’re helpful.
