Create rules stream
I need to create a streams that in the rule have 2 servers and two applications.
I did the following configuration:
Manager stream rules →
application_name must match exactly AppTeste, AppTeste1
server_name must match exactly server01, server02
This setting did not work. Would it be possible to create this rule?
Graylog 3.3.8
Generally speaking it should be possible but we would need more information to evaluate.
Can you post screen shots with all the details about the rule as well as an example message that this rule should fire off on? As much detail as is possible but obfuscated where need be. :slight_smile:
