Couldn't bulk index - Unable to flush message buffer
Hi
I’m using graylog 4.1.6 and I have the error below:
2022-04-12 22:33:50,464 ERROR: org.graylog2.outputs.BlockingBatchedESOutput - Unable to flush message buffer
java.lang.RuntimeException: java.util.concurrent.ExecutionException: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ElasticsearchStatusException[Elasticsearch exception [type=es_rejected_execution_exception, reason=rejected execution of coordinating operation [coordinating_and_primary_bytes=52127833, replica_bytes=0, all_bytes=52127833, coordinating_operation_bytes=2500996, max_coordinating_and_primary_bytes=53687091]]];, errorDetails=[]}
	at org.graylog2.indexer.messages.Messages.runBulkRequest(Messages.java:235) ~[graylog.jar:?]
	at org.graylog2.indexer.messages.Messages.bulkIndexRequests(Messages.java:151) ~[graylog.jar:?]
	at org.graylog2.indexer.messages.Messages.bulkIndex(Messages.java:143) ~[graylog.jar:?]
	at org.graylog2.indexer.messages.Messages.bulkIndex(Messages.java:123) ~[graylog.jar:?]
	at or
Suppressed: org.graylog.shaded.elasticsearch7.org.elasticsearch.client.ResponseException: method [POST], host [http://elastic-graylog:9200], URI [/_bulk?timeout=1m], status line [HTTP/1.1 429 Too Many Requests]
{"error":{"root_cause":[{"type":"es_rejected_execution_exception","reason":"rejected execution of coordinating operation [coordinating_and_primary_bytes=52127833, replica_bytes=0, all_bytes=52127833, coordinating_operation_bytes=2500996, max_coordinating_and_primary_bytes=53687091]"}],"type":"es_rejected_execution_exception","reason":"rejected execution of coordinating operation [coordinating_and_primary_bytes=52127833, replica_bytes=0, all_bytes=52127833, coordinating_operation_bytes=2500996, max_coordinating_and_primary_bytes=53687091]"},"status":429}
		at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.convertResponse(RestClient.java:302) ~[?:?]
		at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:272) ~[?:?]
		at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:246) ~[?:?]
		at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.internalPerformRequest(RestHighLevelClient.java:1613) ~[?:?]
		at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.performRequest(RestHighLevelClient.java:1583) ~[?:?]
		at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.performRequestAndParseEntity(RestHighLevelClient.java:1553) ~[?:?]
		at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.bulk(RestHighLevelClient.java:533) ~[?:?]
with this error too
2022-04-12 22:33:50,646 ERROR: org.graylog2.indexer.messages.Messages - Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ElasticsearchStatusException[Elasticsearch exception [type=es_rejected_execution_exception, reason=rejected execution of coordinating operation [coordinating_and_primary_bytes=52127833, replica_bytes=0, all_bytes=52127833, coordinating_operation_bytes=2514828, max_coordinating_and_primary_bytes=53687091]]];, errorDetails=[]}, retrying (attempt #1).
2022-04-12 22:33:50,646 ERROR: org.graylog2.indexer.messages.Messages - Couldn't bulk index 1000 messages.
java.util.concurrent.ExecutionException: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ElasticsearchStatusException[Elasticsearch exception [type=es_rejected_execution_exception, reason=rejected execution of coordinating operation [coordinating_and_primary_bytes=52127833, replica_bytes=0, all_bytes=52127833, coordinating_operation_bytes=2514828, max_coordinating_and_primary_bytes=53687091]]];, errorDetails=[]}
Is there someone that can help me to understand what is happeninig?
I add the log file too. Please help me
error-log.pdf (482.1 KB)
I looked over you logs. I didn’t notice any “connection” issues, mainly bulk request issues.
What is your Heap for Elasticsearch?
Maybe the answer can be found here.
Insure elasticsearch is working correctly.
Perhaps this site might help
