Console/root password for SU of docker container?
Greetings,
I’m trying to do some network connectivity tests within the docker container itself, and am trying to elevate the console within the container to root so that I can install apt packages temporarily.
I’ve tried su - , and then entering the password i’ve defined for GRAYLOG_ROOT_PASSWORD_SHA2, “admin”, and (blank) to no avail
I at least need to be able to run a ping command from within the container
Does anyone happen to know the password for “root” so that I can run console CLI commands within the container?
There is a whole section on the docker root password here… maybe there is part of a config you are missing?
The password properties specified in it just effect the WebUI Unfortunately.
I should have read that better. :expressionless:
There is a long post here about getting to root on a container, does that help?
Adding on to @tmacgbay stated.
A community member had the same problem here
That only seems to effect the password for the webui ,
I may need to fork the docker file and have it install net tools and other packages during the build so that I can do some troubleshooting. Not a priority though as I abandoned the IPVlan idea for the moment.
