Collectors "Start pattern of multiline" Regular
I have question at Collectors “Start pattern of multiline” , when I set one Regular match it work fine.
But if I set two match string or whatever, it’s not work fine.
Examples:
2017-04-11 or 2017/04/11
I set the regular is like:
/^\d{4}-\d{2}/ =~ /^\d{4}/\d{2}/\d{2}/
or
/^\d{4}-\d{2}/ | /^\d{4}/\d{2}/\d{2}/
How do I set this regular ?
Hej,
if I took your example start - in my setup the following is working:
(^\d{4}-\d{2}-\d{2}|^\d{4}\/\d{2}\/\d{2})
@jan Hi, Jan
I set with you provider and worked fine!
But when I put the regular in the box why display “Invalid pattern”, then I put a string in Stop pattern of multiline and backspace it’s be ok.
