Collector-sidecar configuration first
I try configure collector-sidecar on linux and create tag “log” and in greylog that collector connect but I didn`t have any data in dashboard. In file I try copy file from messages system file.
please read the step-by-step guide in the docs again.
You are missing the step to assign the configuration a tag.
http://docs.graylog.org/en/2.4/pages/collector_sidecar.html#step-by-step-guide
Sorry I do that and I have :
And I didn`t have any data.
according to you screenshot earlier it looks like not.
Did you have created a Input that receive your logs?
You need to create a Beats Input.
I only add tag like in your sceen and then see status like the last screen. Input I create as in screen with “/var/log/log.log”,
He @sata11
you need to create a Input in Graylog where the Collector can send the logs too.
Go to System > Inputs in the Graylog UI and create a Beats input.
What port I select in input (where in client I define port)??
Please, read the documentation - think a few minutes about your question and only if that does not give you the solution post that question.
The Output that is configured for the Collector (beats_output) in your case is what needs to be a valid Input in Graylog (the above described created Input in the Graylog UI on the Input page)
I think is work. I have mistake in input. I have to change greylog server adress from localhost. Why define double input, one in input in collector and one in greylog server
you define one input for the collector - the file you want to be pushed to graylog - and one input on graylog where graylog is listening to receive messages.
