can PLEASE somebody tell me how the syntax of the WinLogBeats Input is. I have:
[{‘name’:‘Application’}] and everything is perfect.
But i need to add things like “ignore_older:72h” or “level: critical, error, warning”?
How can i put this in it?
THX!!
jochen
(Jochen)
2
Can you plese give me a example snipplet like the nxlog example?
Because if i put in:
ignore_older: 72h
a error occurs.
“Error during configuration validation… Invalid top-level key ‘ignore older’.”
I try a lot but no success.
jochen
(Jochen)
4
Where exactly did you enter that snippet and where do you see the error message?
Try this format in “event name”, its working for me.
[{'ignore_older': '1h','name':'Application'},{'ignore_older': '1h','name':'System'},{'ignore_older': '1h','name':'Security'}]
system
(system)
Closed
6
