The output buffer is full due to connection to the output target is not set up yet. It seems I have to restart graylog after deleting the output. Is there any way to purge the output buffer for specific output without restart graylog? I am worrying if the restarting could result in losing other messages already in all the buffers (are the buffers in RAM or disk?)
he @Tiger
the current outputs are in RAM and this is a known limitation and bug. Upcoming versions will work on this to improve.
