Hey Guys,
im trying to split following Cisco FTD message with grok extractors:
%FTD-4-430003: EventPriority: Low, DeviceUUID: bawezh38-d5ewf-113c-8a08-adwde6ac, InstanceID: 3, FirstPacketSecond: 2024-09-04T10:06:25Z, ConnectionID: 21556, AccessControlRuleAction: Block, AccessControlRuleReason: SSL Block, SrcIP: 161.23.161.5, DstIP: 30.193.157.68, SrcPort: 62123, DstPort: 123, Protocol: tcp, IngressInterface: inside, EgressInterface: outside, IngressZone: inside, EgressZone: outside, IngressVRF: Global, EgressVRF: Global, ACPolicy: HDL, AccessControlRuleName: Web, Prefilter Policy: PreFilter_Std, Client: SSL client, ApplicationProtocol: HTTPS, WebApplication: Azure Authentication Service, ConnectionDuration: 0, InitiatorPackets: 3, ResponderPackets: 3, InitiatorBytes: 462, ResponderBytes: 2934, NAPPolicy: Balanced Security and Connectivity, SSLPolicy: SSL_Std, SSLRuleName: Block_unwanted, SSLFlowStatus: Success, SSLCipherSuite: TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384, SSLCertificate: 7b85lk085abc854ecdd16d8ea2813658bbee187b, SSLVersion: TLSv1.2, SSLServerCertStatus: Valid, SSLActualAction: Block, SSLExpectedAction: Block, SSLSessionID: fbe30bca1387f700aa03865d4da8bc7836f571ed850ecda01e8e03931cf63cfc, URL: https://login.live.com, NAT_InitiatorPort: 62453, NAT_ResponderPort: 441, NAT_InitiatorIP: 154.78.20.232, NAT_ResponderIP: 31.195.194.68, EVE_Process: zscaler tunnel, EVE_ProcessConfidencePct: 44, EVE_ThreatConfidencePct: 0, EVE_ThreatConfidenceIndex: 1, ClientAppDetector: AppID
My Problem are not the grok patterns, i use Grok Debugger and the splitting works perfectly, even in the simulation in graylog, it works. But as soon as i save the extractor, the message stops apearing in my Stream. Even more confusing is, when i only extract the SrcIP with grok, it works, but as soon as i try to extract more from the message, new messages stop coming in.
I already tried old extractors, from old posts, but they are all 5-8 years old and dont work for me.
I also tried this Pipeline rule:
https://community.graylog.org/t/creating-a-log-extractor-for-key-value-key-value-logs/20820/2
it’s also not working, i can see that the messages are being put through the pipeline, but dont appear in the Stream.
how do you guys extract cisco logs, do you have working pipeline Rules? Or are you using Extractors? I am having the same problems with splitting my Netscaler messages. It’s obviously some step i am missing, please help ![]()
