Cisco Catalyst switch log on Graylog 2.4.5
I have Graylog 2.4.5 and i want cisco log (catalyst C3750)
I installed Graylog content pack for Cisco (https://marketplace.graylog.org/addons/13a1cae1-a358-4a2f-b46c-b609fbe62455) but i have error when input run (failed)
Configuration input :
bind_address: 0.0.0.0
override_source:
port: 514
recv_buffer_size: 262144
Error on /var/log/graylog-server/server.log (graylog server) :
java.net.SocketException: Permission non accordée
at sun.nio.ch.Net.bind0(Native Method) ~[?:1.8.0_171]
at sun.nio.ch.Net.bind(Net.java:433) ~[?:1.8.0_171]
at sun.nio.ch.DatagramChannelImpl.bind(DatagramChannelImpl.java:691) ~[?:1.8.0_171]
at sun.nio.ch.DatagramSocketAdaptor.bind(DatagramSocketAdaptor.java:91) ~[?:1.8.0_171]
at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.bind(NioDatagramPipelineSink.java:129) [graylog.jar:?]
at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.eventSunk(NioDatagramPipelineSink.java:77) [graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:779) [graylog.jar:?]
at org.jboss.netty.channel.SimpleChannelHandler.bindRequested(SimpleChannelHandler.java:299) [graylog.jar:?]
at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:265) [graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) [graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:784) [graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:582) [graylog.jar:?]
at org.jboss.netty.channel.Channels.bind(Channels.java:561) [graylog.jar:?]
at org.jboss.netty.channel.AbstractChannel.bind(AbstractChannel.java:197) [graylog.jar:?]
at org.jboss.netty.bootstrap.ConnectionlessBootstrap.bind(ConnectionlessBootstrap.java:198) [graylog.jar:?]
at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:136) [graylog.jar:?]
at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) [graylog.jar:?]
at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:84) [graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_171]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_171]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_171]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_171]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_171]
2018-07-13T10:17:40.834+02:00 ERROR [InputLauncher] The [org.graylog2.inputs.raw.udp.RawUDPInput] input with ID <5b18e011046846047e624e3a> misfired. Reason: Permission non accordée.
org.graylog2.plugin.inputs.MisfireException: org.graylog2.plugin.inputs.MisfireException: org.jboss.netty.channel.ChannelException: Failed to bind to: /0.0.0.0:514
at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:158) ~[graylog.jar:?]
Caused by: org.graylog2.plugin.inputs.MisfireException: org.jboss.netty.channel.ChannelException: Failed to bind to: /0.0.0.0:514
at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:155) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
… 7 more
Caused by: org.jboss.netty.channel.ChannelException: Failed to bind to: /0.0.0.0:514
at org.jboss.netty.bootstrap.ConnectionlessBootstrap.bind(ConnectionlessBootstrap.java:204) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.transports.NettyTransport.launch(NettyTransport.java:136) ~[graylog.jar:?]
… 7 more
Caused by: java.net.SocketException: Permission non accordée
at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.bind(NioDatagramPipelineSink.java:129) ~[graylog.jar:?]
at org.jboss.netty.channel.socket.nio.NioDatagramPipelineSink.eventSunk(NioDatagramPipelineSink.java:77) ~[graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:779) ~[graylog.jar:?]
at org.jboss.netty.channel.SimpleChannelHandler.bindRequested(SimpleChannelHandler.java:299) ~[graylog.jar:?]
at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:265) ~[graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) ~[graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:784) ~[graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:582) ~[graylog.jar:?]
at org.jboss.netty.channel.Channels.bind(Channels.java:561) ~[graylog.jar:?]
at org.jboss.netty.channel.AbstractChannel.bind(AbstractChannel.java:197) ~[graylog.jar:?]
at org.jboss.netty.bootstrap.ConnectionlessBootstrap.bind(ConnectionlessBootstrap.java:198) ~[graylog.jar:?]
… 7 more
Please help me !
http://docs.graylog.org/en/2.4/pages/faq.html#how-can-i-start-an-input-on-a-port-below-1024
Depending on the version of IOS you’re running, you should be able to specify a destination port for syslog.
logging host x.x.x.x transport udp port yyyyy
