Checkpoint logs into Graylog
I’m doing some research to try to figure out how folks generally add checkpoint into a graylog instance. Is it via opsec lea, a syslog type configuration, or something else?
The best docs I could find on this sort of thing were here:
Essentially is it the same process for CP or something else?
You could use the procedure described in the blog article you’ve linked to and use the Logstash GELF output to send structured log messages to Graylog.
