Checking condition in a pipeline
HI All,
I wonder is someone could help me out.
I want to write a pipeline rule checks two conditions and sets a field.
Example
// function to detect bad things
rule "lets detect bad stuff"
   // To save CPU cycles, only run on this field in stream
   has_field("sysmon_event_id") AND
	set_field("BadDetected", "true");
The logic in the when condition is something similar to below
If sysmon_eventid=11 and granted-access=0x100 then set field
Both sysmon_event_id and granted access are fields and can be searched on inn the search bar with this
(sysmon_event_id:11 AND GrantedAccess:“0x100”)
Does this logic work in functions?
Cheers Jake
Yes, it does. You can use various boolean operators (AND, OR, NOT) to chain conditions in the when clause of your rules.
See http://docs.graylog.org/en/2.4/pages/pipelines/rules.html for details.
Hi Jochen,
So something like this.
   // sets check for the presence of both fields
   has_field("sysmon_event_id") && has_field("GrantedAccess")
        contains(to_string($message.sysmon_event_id","11") && (to_string($message.GrantedAccess","0x100");
Would this work?
Cheers Jake
it should be more like:
rule “lets detect bad stuff”
  has_field(“sysmon_event_id”) AND
  has_field(“GrantedAccess”) AND
  contains(to_string($message.sysmon_event_id,“11”) AND
  contains(to_string($message.GrantedAccess,“0x100”)
  set_field(“BadDetected”, “true”);
Hi Jochen,
I get an incompatable types error see
So I tried
Am i missing a semi colon or something somewhere?
Cheers
Jake
Hej Jake,
actually I just wrote the rule direct in the Forum - not in the editor. That is just missing ) and wrong " and I missed the order of contains (first value then the string)
  has_field("GrantedAccess") AND
  contains("11",to_string($message.sysmon_event_id)) AND
  contains("0x100", to_string($message.GrantedAccess))
Hi Jochen,
Cheers for your help once again, I have Graylog doing something special.
Cheers
Jake
