Can't connect to preflight using graylog 7 docker compose file
Can’t access preflight UI with docker graylog7, I only get a connection refused. graylog container is also marked as unhealthy…
  • OS Information: Debian 13
  • Package Version: graylog/graylog:7.0
Docker Compose file (straight from the repo)
# For DataNode setup, graylog starts with a preflight UI, this is a change from just using OpenSearch/Elasticsearch.
# Please take a look at the README at the top of this repo or the regular docs for more info.
services:
  mongodb:
    image: "mongo:7.0"
    restart: "on-failure"
    networks:
      - graylog
    volumes:
      - "mongodb_data:/data/db"
      - "mongodb_config:/data/configdb"
  # Graylog Data Node: https://hub.docker.com/r/graylog/graylog-datanode
  # ⚠️ Make sure this is set on the host before starting:
  # echo "vm.max_map_count=262144" | sudo tee -a /etc/sysctl.conf
  # sudo sysctl -p
  datanode:
    image: "${DATANODE_IMAGE:-graylog/graylog-datanode:7.0}"
    hostname: "datanode"
    environment:
      GRAYLOG_DATANODE_NODE_ID_FILE: "/var/lib/graylog-datanode/node-id"
      # GRAYLOG_DATANODE_PASSWORD_SECRET and GRAYLOG_PASSWORD_SECRET MUST be the same value
      GRAYLOG_DATANODE_PASSWORD_SECRET: "${GRAYLOG_PASSWORD_SECRET:?Please configure GRAYLOG_PASSWORD_SECRET in the .env file}"
      GRAYLOG_DATANODE_MONGODB_URI: "mongodb://mongodb:27017/graylog"
    ulimits:
      memlock:
        hard: -1
        soft: -1
      nofile:
        soft: 65536
        hard: 65536
    ports:
      - "127.0.0.1:8999:8999/tcp"   # DataNode API
      - "127.0.0.1:9200:9200/tcp"
      - "127.0.0.1:9300:9300/tcp"
    networks:
      - graylog
    volumes:
      - "graylog-datanode:/var/lib/graylog-datanode"
  # Graylog: https://hub.docker.com/r/graylog/graylog-enterprise
  graylog:
    hostname: "server"
    image: "${GRAYLOG_IMAGE:-graylog/graylog:7.0}"
    depends_on:
      mongodb:
        condition: "service_started"
      datanode:
    entrypoint: "/usr/bin/tini --  /docker-entrypoint.sh"
    environment:
      GRAYLOG_NODE_ID_FILE: "/usr/share/graylog/data/data/node-id"
      GRAYLOG_PASSWORD_SECRET: "${GRAYLOG_PASSWORD_SECRET:?Please configure GRAYLOG_PASSWORD_SECRET in the .env file}"
      GRAYLOG_ROOT_PASSWORD_SHA2: "${GRAYLOG_ROOT_PASSWORD_SHA2:?Please configure GRAYLOG_ROOT_PASSWORD_SHA2 in the .env file}"
      GRAYLOG_HTTP_BIND_ADDRESS: "0.0.0.0:9000"
      GRAYLOG_HTTP_EXTERNAL_URI: "http://192.168.69.240:9000/"
      GRAYLOG_MONGODB_URI: "mongodb://mongodb:27017/graylog"
    ports:
    - "127.0.0.1:5044:5044/tcp"   # Beats
    - "127.0.0.1:5140:5140/udp"   # Syslog
    - "127.0.0.1:5140:5140/tcp"   # Syslog
    - "127.0.0.1:5555:5555/tcp"   # RAW TCP
    - "127.0.0.1:5555:5555/udp"   # RAW UDP
    - "127.0.0.1:9000:9000/tcp"   # Server API
    - "127.0.0.1:12201:12201/tcp" # GELF TCP
    - "127.0.0.1:12201:12201/udp" # GELF UDP
    #- "127.0.0.1:10000:10000/tcp" # Custom TCP port
    #- "127.0.0.1:10000:10000/udp" # Custom UDP port
    - "127.0.0.1:13301:13301/tcp" # Forwarder data
    - "127.0.0.1:13302:13302/tcp" # Forwarder config
    networks:
      - graylog
    volumes:
      - "graylog_data:/usr/share/graylog/data/data"
networks:
  graylog:
    driver: "bridge"
volumes:
  mongodb_data:
  mongodb_config:
  graylog-datanode:
  graylog_data:
Offending graylog container
docker container logs 0c672bcc3f15
2026-01-10 07:41:11,226 INFO : org.graylog2.featureflag.ImmutableFeatureFlagsCollector - Following feature flags are used: {default properties file=[show_security_events_in_pedt=off, data_tiering_cloud=off, preflight_web=on, configurable_value_units=on, setup_mode=on, cloud_inputs=on, investigation_report_by_ai=on, show_executive_dashboard_page=off, collections=on, composable_index_templates=off, data_node_migration=on, remote_reindex_migration=off, instant_archiving=off, data_lake_search=on, widget_summary=on, threat_coverage=on, external_data_lake_search=on]}
2026-01-10 07:41:12,312 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: AWS plugins 7.0.3+cf37d91 [org.graylog.aws.AWSPlugin]
2026-01-10 07:41:12,313 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Integrations 7.0.3+cf37d91 [org.graylog.integrations.IntegrationsPlugin]
2026-01-10 07:41:12,315 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Threat Intelligence Plugin 7.0.3+cf37d91 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2026-01-10 07:41:12,317 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Elasticsearch 7 Support 7.0.3+cf37d91 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2026-01-10 07:41:12,317 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: OpenSearch 2 Support 7.0.3+cf37d91 [org.graylog.storage.opensearch2.OpenSearch2Plugin]
2026-01-10 07:41:12,349 INFO : org.graylog2.bootstrap.CmdLineTool - Running with JVM arguments: -Dlog4j2.formatMsgNoLookups=true -Djdk.tls.acknowledgeCloseNotify=true -XX:+UnlockExperimentalVMOptions -XX:-OmitStackTraceInFastThrow -XX:+UseG1GC -Dlog4j.configurationFile=/usr/share/graylog/data/config/log4j2.xml -Dgraylog2.installation_source=docker
2026-01-10 07:41:12,652 INFO : org.mongodb.driver.client - MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "5.6.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.12.57+deb13-amd64"}, "platform": "Java/Eclipse Adoptium/21.0.9+10-LTS", "env": {"container": {"runtime": "docker"}}} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@2373ad99, com.mongodb.Jep395RecordCodecProvider@33634f04, com.mongodb.KotlinCodecProvider@4993febc, EnumCodecProvider{}]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[mongodb:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2026-01-10 07:41:12,676 INFO : org.mongodb.driver.client - MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "5.6.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.12.57+deb13-amd64"}, "platform": "Java/Eclipse Adoptium/21.0.9+10-LTS", "env": {"container": {"runtime": "docker"}}} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@2373ad99, com.mongodb.Jep395RecordCodecProvider@33634f04, com.mongodb.KotlinCodecProvider@4993febc, EnumCodecProvider{}]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[mongodb:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2026-01-10 07:41:12,768 INFO : org.mongodb.driver.cluster - Monitor thread successfully connected to server with description ServerDescription{address=mongodb:27017, type=STANDALONE, cryptd=false, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=21, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=74719986, minRoundTripTimeNanos=0}
2026-01-10 07:41:12,791 INFO : org.mongodb.driver.cluster - Waiting for server to become available for operation { ping: 1 } with ID 3. Remaining time: 29980 ms. Selector: ReadPreferenceServerSelector{readPreference=primary}, topology description: {type=UNKNOWN, servers=[{address=mongodb:27017, type=UNKNOWN, state=CONNECTING}].
2026-01-10 07:41:12,883 INFO : org.graylog2.bootstrap.preflight.MongoDBPreflightCheck - Connected to MongoDB version 7.0.28
2026-01-10 07:41:13,857 INFO : org.mongodb.driver.client - MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "5.6.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.12.57+deb13-amd64"}, "platform": "Java/Eclipse Adoptium/21.0.9+10-LTS", "env": {"container": {"runtime": "docker"}}} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@2373ad99, com.mongodb.Jep395RecordCodecProvider@33634f04, com.mongodb.KotlinCodecProvider@4993febc, EnumCodecProvider{}]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[mongodb:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2026-01-10 07:41:13,863 INFO : org.mongodb.driver.cluster - Monitor thread successfully connected to server with description ServerDescription{address=mongodb:27017, type=STANDALONE, cryptd=false, state=CONNECTED, ok=true, minWireVersion=0, maxWireVersion=21, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=3393999, minRoundTripTimeNanos=0}
2026-01-10 07:41:13,871 INFO : org.mongodb.driver.client - MongoClient with metadata {"driver": {"name": "mongo-java-driver|legacy", "version": "5.6.1"}, "os": {"type": "Linux", "name": "Linux", "architecture": "amd64", "version": "6.12.57+deb13-amd64"}, "platform": "Java/Eclipse Adoptium/21.0.9+10-LTS", "env": {"container": {"runtime": "docker"}}} created with settings MongoClientSettings{readPreference=primary, writeConcern=WriteConcern{w=null, wTimeout=null ms, journal=null}, retryWrites=true, retryReads=true, readConcern=ReadConcern{level=null}, credential=null, transportSettings=null, commandListeners=[], codecRegistry=ProvidersCodecRegistry{codecProviders=[ValueCodecProvider{}, BsonValueCodecProvider{}, DBRefCodecProvider{}, DBObjectCodecProvider{}, DocumentCodecProvider{}, CollectionCodecProvider{}, IterableCodecProvider{}, MapCodecProvider{}, GeoJsonCodecProvider{}, GridFSFileCodecProvider{}, Jsr310CodecProvider{}, JsonObjectCodecProvider{}, BsonCodecProvider{}, com.mongodb.client.model.mql.ExpressionCodecProvider@2373ad99, com.mongodb.Jep395RecordCodecProvider@33634f04, com.mongodb.KotlinCodecProvider@4993febc, EnumCodecProvider{}]}, loggerSettings=LoggerSettings{maxDocumentLength=1000}, clusterSettings={hosts=[mongodb:27017], srvServiceName=mongodb, mode=SINGLE, requiredClusterType=UNKNOWN, requiredReplicaSetName='null', serverSelector='null', clusterListeners='[]', serverSelectionTimeout='30000 ms', localThreshold='15 ms'}, socketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=0, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, heartbeatSocketSettings=SocketSettings{connectTimeoutMS=10000, readTimeoutMS=10000, receiveBufferSize=0, proxySettings=ProxySettings{host=null, port=null, username=null, password=null}}, connectionPoolSettings=ConnectionPoolSettings{maxSize=1000, minSize=0, maxWaitTimeMS=120000, maxConnectionLifeTimeMS=0, maxConnectionIdleTimeMS=0, maintenanceInitialDelayMS=0, maintenanceFrequencyMS=60000, connectionPoolListeners=[], maxConnecting=2}, serverSettings=ServerSettings{heartbeatFrequencyMS=10000, minHeartbeatFrequencyMS=500, serverMonitoringMode=AUTO, serverListeners='[]', serverMonitorListeners='[]'}, sslSettings=SslSettings{enabled=false, invalidHostNameAllowed=false, context=null}, applicationName='null', compressorList=[], uuidRepresentation=UNSPECIFIED, serverApi=null, autoEncryptionSettings=null, dnsClient=null, inetAddressResolver=null, contextProvider=null, timeoutMS=null}
2026-01-10 07:41:13,997 INFO : org.graylog2.plugin.system.FilePersistedNodeIdProvider - No node ID file found. Generated: f39e4526-ea44-44ad-aa94-dacc7390f363
2026-01-10 07:41:14,069 INFO : org.graylog2.configuration.IndexerDiscoveryProvider - No indexer hosts configured, using fallback http://127.0.0.1:9200
2026-01-10 07:41:14,683 INFO : org.graylog2.bootstrap.ServerBootstrap - Running 2 migrations of type PREFLIGHT...
2026-01-10 07:41:14,747 INFO : org.graylog2.bootstrap.ServerBootstrap - Fresh installation detected, starting configuration webserver
2026-01-10 07:41:14,753 INFO : org.graylog2.shared.initializers.PeriodicalsService - Starting 3 periodicals ...
2026-01-10 07:41:14,759 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.bootstrap.preflight.GraylogCertificateProvisioningPeriodical] periodical in [2s], polling every [2s].
2026-01-10 07:41:14,762 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2026-01-10 07:41:14,764 INFO : org.graylog2.periodical.Periodicals - Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2026-01-10 07:41:15,931 INFO : org.hibernate.validator.internal.util.Version - HV000001: Hibernate Validator 9.0.1.Final
2026-01-10 07:41:16,461 INFO : org.glassfish.grizzly.http.server.NetworkListener - Started listener bound to [0.0.0.0:9000]
2026-01-10 07:41:16,464 INFO : org.glassfish.grizzly.http.server.HttpServer - [HttpServer] Started.
2026-01-10 07:41:16,469 INFO : org.graylog2.bootstrap.preflight.PreflightJerseyService -
It seems you are starting Graylog for the first time. To set up a fresh install, a setup interface has
been started. You must log in to it to perform the initial configuration and continue.
Initial configuration is accessible at 0.0.0.0:9000, with username 'admin' and password 'bnorTrqTwj'.
Try clicking on http://admin:bnorTrqTwj@0.0.0.0:9000
Have tried to define the secret values in case it was that. Also have tried directly configuring the GRAYLOG_HTTP_EXTERNAL_URI to the actual host IP and still cannot connect.
We are very new to graylog and we are also very new to the idea of using something like graylog and so far, not having a great time getting this up and running on a VM that I have locally at home before I dare push this to my production environment.
Hey @MaxTakeba
I just tried the docker-compose you are posting and everything starts fine for me, the preflight interface is available on http://localhost:9000/, with the admin username and password printed in the logs.
What URL are you trying to access?
Maybe this is related to your problem?
Unfortunately that PR which Tomas provided can’t be merged, because of security problems then. What you can do for your environment, just delete 127.0.0.1 from ports section in Data Node and Graylog. That should fix your problem
