Cannot login fresh installation of Graylog on docker
Invalid credentials, please verify them and retry.
I am not able to log in Graylog UI running on docker. I’m making use of the environment variable file.
I can’t see anything obvious in the logs apart from wrong credentials. Any help how I can solve this?
VM on an ESXi host
  • OS Information:
Ubuntu 24.04 running Docker version 24.0.5, build ced0996
version: “3.8”
services:
mongodb:
image: “mongo:5.0”
volumes:
- “mongodb_data:/data/db”
restart: “on-failure”
opensearch:
image: “opensearchproject/opensearch:2.4.0”
environment:
- “OPENSEARCH_JAVA_OPTS=-Xms1g -Xmx1g”
- “bootstrap.memory_lock=true”
- “discovery.type=single-node”
- “action.auto_create_index=false”
- “plugins.security.ssl.http.enabled=false”
- “plugins.security.disabled=true”
ulimits:
memlock:
hard: -1
soft: -1
nofile:
soft: 65536
hard: 65536
volumes:
- “os_data:/usr/share/opensearch/data”
graylog:
hostname: “server”
image: “${GRAYLOG_IMAGE:-graylog/graylog:5.1.5}”
depends_on:
opensearch:
condition: “service_started”
mongodb:
entrypoint: “/usr/bin/tini – wait-for-it opensearch:9200 – /docker-entrypoint.sh”
environment:
GRAYLOG_NODE_ID_FILE: “/usr/share/graylog/data/config/node-id”
GRAYLOG_PASSWORD_SECRET: “$${GRAYLOG_PASSWORD_SECRET:?Please configure GRAYLOG_PASSWORD_SECRET in the .env file}”
GRAYLOG_ROOT_PASSWORD_SHA2: “$${GRAYLOG_ROOT_PASSWORD_SHA2:?Please configure GRAYLOG_ROOT_PASSWORD_SHA2 in the .env file}”
GRAYLOG_HTTP_BIND_ADDRESS: “0.0.0.0:9000”
GRAYLOG_HTTP_EXTERNAL_URI: “http://localhost:9000/”
GRAYLOG_ELASTICSEARCH_HOSTS: “http://opensearch:9200”
GRAYLOG_MONGODB_URI: “mongodb://mongodb:27017/graylog”
ports:
- “5044:5044/tcp” # Beats
- “5140:5140/udp” # Syslog
- “5140:5140/tcp” # Syslog
- “5555:5555/tcp” # RAW TCP
- “5555:5555/udp” # RAW TCP
- “9000:9000/tcp” # Server API
- “12201:12201/tcp” # GELF TCP
- “12201:12201/udp” # GELF UDP
#- “10000:10000/tcp” # Custom TCP port
#- “10000:10000/udp” # Custom UDP port
- “13301:13301/tcp” # Forwarder data
- “13302:13302/tcp” # Forwarder config
volumes:
- “graylog_data:/usr/share/graylog/data/data”
- “graylog_journal:/usr/share/graylog/data/journal”
volumes:
mongodb_data:
os_data:
graylog_data:
graylog_journal:
graylog.env
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
# ATTENTION: This value must be the same on all Graylog nodes in the cluster.
# Changing this value after installation will render all user sessions and encrypted values in the database invalid. (e.g. encrypted access tokens)
GRAYLOG_PASSWORD_SECRET=“AYxn7O0Fg3YJkpVhKQHgiWzfWs1JhvahMBG11twfIdlRwExUXHblts9XlYyt7zQTIo8Zj4vNgqtFkj5wsysUVMMX4hvlHIRV”
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
# CHANGE THIS!
GRAYLOG_ROOT_PASSWORD_SHA2=“ce1dedff58447c834034af15c7c139aa1ad6149366ad8c87984058ae98ae4dae”
I have generated a number of hashes using also passwords that have no special characters, each time restarting or even tried to delete all my containers and images and have them built again.
@dubfunkle This might be obvious but when setting the password variables directly in the compose file does it then load?
Also just an observation but you are using an older version of Graylog, 6.0 is the latest stable release.
Good question. I haven’t tried that to be honest so will try it and let you know! Thanks
