Can not copy message to 2 indexes with different fiels per index
can not copy message to 2 indexes with different fiels per index
tried ordering stages differently,
tried applying Stream Tags in Stream view instead of in Pipeline
tried to put “remove” rule to different pipeline
I created one pipeline connected to all messages stream using this rule:
STAGE 0
rule “pipeline with user”
true
let nocomma = to_string($message.message);
//GROK message & overwrite ingest timestamp with logfile timestamp
let groked_message = grok(pattern: “%{TIMESTAMP_ISO8601:logdate}\t ?%{DATA:loglevel}\t ?%{DATA:class}\t ?(%{DATA:user})?”, value: nocomma, only_named_captures: true);
set_fields(groked_message);
route_to_stream(id:“64463448d997114cd1cb3bbd”,remove_from_default:true);
STAGE 1
rule “remove User and store in other index”
true
remove_field(“user”);
route_to_stream(“5de0dc734bc67705e4eb022d”);
Each stream id has a different ES index assigned.
Problem is that the “remove_field()” command removes the user field from both Streams. How can I achieve that I end up with an Stream that contains the user-field and another Stream that does not contain the user-field?
when you route your message to another stream you are adding the ID to the “streams” field. The message stays the same, therefore you are removing your user from both messages.
What you need to do is to clone the message with all its fields, but without the user-field into another message.
If you don’t want to store the message (almost) twice in your database, you might consider decorators to hide/scramble the users.
Thank you @ihe .
Clone did the job.
For others going the same route my final solution looked similar to this:
STAGE 0
rule “fork messages”
true
let x = clone_message();
remove_field(“user”, x);
route_to_stream(id:“5de0dc734bc67705e4eb022d”, message:x);
this allows me to give some of my users a Stream with less fields. But of cause the space consumption nearly doubled.
