Can a pipeline rule to match the same pattern multiple times?
I have a proxy that is inserting several cookies into each request that all match the same regex pattern and I’d like to use a pipeline rule to turn them all into fields.
There can be 1-4 of these cookies in each request.
How do I get the rule to match multiple occurrences of a pattern and put each one into a different field?
Example:
Sfje93hal=alafjawoifawfpaw849rq3948rawif0834f;
Current rule that is working to match first occurrence:
rule “extract cookies”
has_field(“application_name”)
let rawmsg = to_string($message.message);
let result = regex("(AS\w{8}=\w+;)", rawmsg);
set_field(“cookie1”, result[“0”]);
I did not trued, but maybe this?
set_field(“cookie2”, result[“1”]);
set_field(“cookie3”, result[“2”]);
set_field(“cookie4”, result[“3”]);
Oh… right shoulda thought of that myself.
I thought the returned array was an array of properties. Makes more sense that it’s an array of matches.
I’ll try it thanks!
