Build Correlation
I tried to build a correlation using log sources. As per my requirement I need to filter a source_ip address from one log source which has been blocked by IPS and I need to checked that blocked source_ip with another log source, source_ip whether matching attemps are there ?
source:server_a AND status:blocked AND srcip: (should match with) source:server_b AND scrip
Tried several possible logical condition. But unable to create it. Any idea on this are warmly welcome
Maybe this plugin can help you - but with vanilla Graylog that is not possible.
How to I install given plugin in Graylog ?
please read the documentation.
