Best way to extract IPv4 addresses in a pipeline?
Hi there
I want graylog to auto-parse incoming syslog messages and extract srcIP/dstIP pairs. So I came up with this
rule "function ExtractIPv4Pairs"
    regex(".*[^0-9a-zA-Z]([0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3})[^0-9a-zA-Z].*[^0-9a-zA-Z]([0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3})[^0-9a-zA-Z].*",to_string($message.message)).matches
    let pair =  regex(".*[^0-9a-zA-Z]([0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3})[^0-9a-zA-Z].*[^0-9a-zA-Z]([0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3}\\.[0-9]{1,3})[^0-9a-zA-Z].*",to_string($message.message),["src","dst"]);
    set_field("pipeSrcIPv4",to_ip(pair.src));
    set_field("pipeDstIPv4",to_ip(pair.dst));
That works fine - except it can match “1.2.333.4” - which is not a valid IP address. This then generates java crash dumps in the server logs as it isn’t parsable/etc
So what I really need to do is ensure each of those quads are between 0 and 255, etc
Does anyone have a “pure” way of extracting IPv4 (IPv6 too would be great) within a pipeline function?
Jason
You could use a Grok pattern or at least take a look at how the IPV4 Grok pattern has been defined:
OK, good point, I could have googled “ipv4 regex” instead of wasting this lists time :wink:
