Can you advise me on the reception of log from a remote site in case:
- A single remote server
- A remote site with several servers (So a server can be use at gateway)
I’m testing AMQP for the moment (Case number 2) but it’s really not stable for the moment … Logstash crash depending on the type of data it receives I don’t understand much … I tell myself that 'should there be a simpler method?
