Diablo2050
(Amr Rashad)
1
I’m currently testing out graylog and i need to “grep” for a word in message field and update another field.
my code is
rule “csf add”
has_field(“message”) AND contains (“Firewall”, to_string($message.message))
set_field(“filebeat_prospector_type”, “csf”);
vini
(vini)
2
You should try to split the message by space or commas, and then get the position of the string you need.
Message: The word I need is Graylog
Index: 0 1 2 3 4 5
rule “example”
true
let m = split(" ", to_string($message.message));
set_field(“new field”, m[5]);
new_field = Graylog
