AWS-Kinesis/cloudwatch throwing error in graylog logs -Not in GZIP format
Hi All,
I have installed graylog 3.3.0 with elastic 6.8.1 and mongo 3.6.17 versions in my env and I have setup AWS Kinesis/cloudwatch input and I did setup of kinesis stream to receive cloudwatch events and process them into graylog.
I can see in cloudwatch events are generated and below is the message I can see it in graylog,
aws_kinesis_stream
newstream
message
{“version”:“0”,“id”:“7683d207-b31c-41778f685865”,“detail-type”:“CloudWatch Alarm State Change”,“source”:“aws.cloudwatch”,“account”:“0873467805”,“time”:“2020-07-08T14:37:13Z”,“region”:“us-east-1”,“resources”:[“arn:aws:cloudwatch:us-east-1:0873467805:alarm:test-demo-web cpu utilization > 1%”],“detail”:{“alarmName”:“test-demo-web cpu utilization > 1%”,“state”:{“value”:“OK”,“reason”:“Threshold Crossed: 1 out of the last 1 datapoints [1.960655737704196 (08/07/20 14:32:00)] was not greater than the threshold (80.0) (minimum 1 datapoint for ALARM → OK transition).”,“reasonData”:“{“version”:“1.0”,“queryDate”:“2020-07-08T14:37:13.251+0000”,“startDate”:“2020-07-08T14:32:00.000+0000”,“statistic”:“Average”,“period”:60,“recentDatapoints”:[1.960655737704196],“threshold”:80.0}”,“timestamp”:“2020-07-08T14:37:13.254+0000”},“previousState”:{“value”:“INSUFFICIENT_DATA”,“reason”:“Insufficient Data: 1 datapoint was unknown.”,“reasonData”:“{“version”:“1.0”,“queryDate”:“2020-07-08T14:34:13.248+0000”,“statistic”:“Average”,“period”:60,“recentDatapoints”:,“threshold”:80.0}”,“timestamp”:“2020-07-08T14:34:13.252+0000”},“configuration”:{“description”:“CPU Utilization of test-demo-web ec2 instance > 2%”,“metrics”:[{“id”:“14b99746-cbb-67dfa817a1cc”,“metricStat”:{“metric”:{“namespace”:“AWS/EC2”,“name”:“CPUUtilization”,“dimensions”:{“InstanceId”:“i-06a9k903d6b826b6”}},“period”:60,“stat”:“Average”},“returnData”:true}]}}}
source
aws-kinesis-raw-logs
timestamp
2020-07-08T14:37:13.649Z
and I manually changed the aws_message_type from KINESIS_RAW TO KINESIS_CLOUDWATCH_RAW in the input which I created and I tried to generated new events and events are seen in cloudwatch but in graylog log I am getting the below error,
2020-07-08 13:02:44,355 INFO    [DiagnosticEventLogger] - Current thread pool executor state: ExecutorStateEvent(executorName=SchedulerThreadPoolExecutor, currentQueueSize=0, activeThreads=0, coreThreads=0, leasesOwned=1, largestPoolSize=2, maximumPoolSize=2147483647) - {}
2020-07-08 13:03:02,266 ERROR   [KinesisShardProcessorFactory$KinesisShardProcessor] - Could not read Kinesis record from stream [teststream] - {}
java.util.zip.ZipException: Not in GZIP format
        at java.util.zip.GZIPInputStream.readHeader(GZIPInputStream.java:165) ~[?:1.8.0_252]
        at java.util.zip.GZIPInputStream.<init>(GZIPInputStream.java:79) ~[?:1.8.0_252]
        at java.util.zip.GZIPInputStream.<init>(GZIPInputStream.java:91) ~[?:1.8.0_252]
        at org.graylog2.plugin.Tools.decompressGzip(Tools.java:239) ~[graylog.jar:?]
        at org.graylog2.plugin.Tools.decompressGzip(Tools.java:227) ~[graylog.jar:?]
        at org.graylog.integrations.aws.transports.KinesisPayloadDecoder.decompressCloudWatchMessages(KinesisPayloadDecoder.java:100) ~[graylog-plugin-integrations-3.3.0.jar:?]
        at org.graylog.integrations.aws.transports.KinesisPayloadDecoder.processMessages(KinesisPayloadDecoder.java:64)
        at org.graylog.integrations.aws.transports.KinesisShardProcessorFactory$KinesisShardProcessor.processRecords(KinesisShardProcessorFactory.java:98) [graylog-plugin-integrations-3.3.0.jar:?]
        at software.amazon.kinesis.lifecycle.ProcessTask.callProcessRecords(ProcessTask.java:200) [graylog-plugin-integrations-3.3.0.jar:?]
        at software.amazon.kinesis.lifecycle.ProcessTask.call(ProcessTask.java:141) [graylog-plugin-integrations-3.3.0.jar:?]
        at software.amazon.kinesis.lifecycle.ShardConsumer.executeTask(ShardConsumer.java:327) [graylog-plugin-integrations-3.3.0.jar:?]
        at software.amazon.kinesis.lifecycle.ShardConsumer.processData(ShardConsumer.java:313) [graylog-plugin-integrations-3.3.0.jar:?]
        at software.amazon.kinesis.lifecycle.ShardConsumer.handleInput(ShardConsumer.java:146) [graylog-plugin-integrations-3.3.0.jar:?]
        at software.amazon.kinesis.lifecycle.ShardConsumerSubscriber.onNext(ShardConsumerSubscriber.java:156) [graylog-plugin-integrations-3.3.0.jar:?]
        at software.amazon.kinesis.lifecycle.ShardConsumerSubscriber.onNext(ShardConsumerSubscriber.java:35) [graylog-plugin-integrations-3.3.0.jar:?]
        at software.amazon.kinesis.lifecycle.NotifyingSubscriber.onNext(NotifyingSubscriber.java:56) [graylog-plugin-integrations-3.3.0.jar:?]
        at software.amazon.kinesis.lifecycle.NotifyingSubscriber.onNext(NotifyingSubscriber.java:27) [graylog-plugin-integrations-3.3.0.jar:?]
        at io.reactivex.internal.util.HalfSerializer.onNext(HalfSerializer.java:45) [graylog-plugin-integrations-3.3.0.jar:?]
        at io.reactivex.internal.subscribers.StrictSubscriber.onNext(StrictSubscriber.java:97) [graylog-plugin-integrations-3.3.0.jar:?]
        at io.reactivex.internal.operators.flowable.FlowableObserveOn$ObserveOnSubscriber.runAsync(FlowableObserveOn.java:400) [graylog-plugin-integrations-3.3.0.jar:?]
        at io.reactivex.internal.operators.flowable.FlowableObserveOn$BaseObserveOnSubscriber.run(FlowableObserveOn.java:176) [graylog-plugin-integrations-3.3.0.jar:?]
        at io.reactivex.internal.schedulers.ExecutorScheduler$ExecutorWorker$BooleanRunnable.run(ExecutorScheduler.java:261) [graylog-plugin-integrations-3.3.0.jar:?]
        at io.reactivex.internal.schedulers.ExecutorScheduler$ExecutorWorker.run(ExecutorScheduler.java:226) [graylog-plugin-integrations-3.3.0.jar:?]
Please correct me if my understanding is wrong and also I was expecting the msg should get parsed automatically.
let me know your thoughts
Regards,
Ganeshbabu R
Taking a quick look into this, in the case where the message type is KINESIS_CLOUDWATCH_RAW or KINESIS_CLOUDWATCH_FLOW_LOGS, we do attempt to unzip prior to processing here in the KinesisPayloadDecoder. We’re doing this because the AWS documentation for Using CloudWatch Logs Subscription Filters (Example 1, Step 8) says:
The Data attribute in a Kinesis record is Base64 encoded and compressed with the gzip format.
What I don’t see is us doing a Base64 decode prior to unzipping, which could be a problem. We will need to take a deeper look and see if this lack of Base64 decoding really is is the root cause of the issue.
It appears I was mistaken about the Base64 decode.
The difference between KINESIS_RAW and KINESIS_CLOUDWATCH_RAW is that when the message type is set to KINESIS_CLOUDWATCH_RAW, Graylog expects the data it pulls from Kinesis to be zipped. Graylog does not perform additional automatic parsing for the KINESIS_CLOUDWATCH_RAW message type beyond what is already done for the KINESIS_RAW message type.
If your input is producing data using the KINESIS_RAW message type, there is no reason to switch to KINESIS_CLOUDWATCH_RAW message type.
