Archive Retention
We are using the 5GB Enterprise licence which has Archiving.
My intent is 1M online and 5M archive/offline. I have the Indices configures for 4 and then archive, which is working.
My question: Is there a way within GL to control the number of archives retained? … Or would I do that at the OS / Cron level?
Paul
the archiving is build to hold the data forever.
Which means if you want to make housekeeping that needs to be done outsite.
The 5GB License is for 5GB ingest into Elasticsearch search not for 5GB Data in Elasticsearch. Just to make sure that you notice that.
Perfect - Thanks for the reply
