Alerts on content by count
I’m trying to figure out if this is possible with the current alert conditions. I understand we can alert by count and we can alert by content but what if I want an alert after a field value has Y come in X number of times? (I’m not sure I understand the aggregate condition, an explanation would be appreciated)
In our environment, every updown cisco event, after going through a pipeline, gets a field added with the source and interface concatenated. That way we use quick values on a dashboard to check what interfaces may be acting up.
so lets say in the last 5 minutes the field “interface” has had the following values:
192.168.1.109-GE2/6
192.168.1.111-GE0/16
192.168.1.111-GE0/15
192.168.1.109-GE2/6
192.168.1.109-GE2/2
192.168.1.109-GE2/6
192.168.1.109-GE2/1
192.168.1.109-GE2/6
192.168.1.216-GE6/32
How can I get alerted if field “interface” gets a count of 5+ of the same value? so for the example above alerting me that “interface” has gone over the threshold with value “192.168.1.111-GE0/15” being logged more than 5 times within the last 5 minutes
Thanks,
Stephen
In my system I use scripts to do this. I’ll have a stream that gets messages that say contain your interface field. Then I have an alert for an HTTP callback for any messages that come in the stream that sends to a server with a perl script that parses the POST information and does the alert logic from there.
@desertjedi85 Thtats a good idea and if there is no actual way to do this within graylog, I will definitely consider that.
However, if there is a way to accomplish this without the introduction of another server that’d be ideal
Hej @sgarciam
please raise a feature issue over at github for that.
thank you
Jan
Was about to but it seems @joruro beat me to it :slight_smile:
After testing, the Aggregates plugin available on the marketplace made by cvtienhoven does work for this purpose thou it would be great to see it implemented within the alerts framework.
