After extend disk but cannot mount
I use Graylog on VM . I extend disk on VM and use command-line to extend size of disk.
But i cannot mount for /var/opt/graylog/data
I suggest a case of man mount - you’re trying to mount an entire disk as a partition, you may want to specify the partition itself, such as /dev/sdb1 or somesuch…
