Hi All,
Is there a way to add a text box to a dashboard giving an explanation of a widget?
Obviously you add explanatory text as part of the title.
Cheers
Jake
Hi All,
Cheers
Jake
No, that’s currently not supported out of the box.
It should be possible to provide this kind of widget via a plugin.
Hi Jochen,
Would it be worth adding as a feature request on github?
Jake
Sure, why not: Issues · Graylog2/graylog2-server · GitHub
This is something that I’m interested as well. As I didn’t see an issue/feature request done by Magneton, I did here:
Cheers for that as I did not get around to it yet.
Jake
