Hi, i accidentally added role with slash , so i cannot delete it. I wrote on github an issue bug . How can i delete role may be through mongo ?
Hi Artem,
you can try using the URL-encoded variant of the /
character, which is %2F
curl -u $USER:$PASSWORD -X DELETE http://127.0.0.1:9000/api/roles/%20Stream%2FDashboard%20Editor/members
i got this error: > {“type”:“ApiError”,“message”:“HTTP 405 Method Not Allowed”}
Is the Graylog REST API running on http://127.0.0.1:9000/api/
in your setup?
nope , i use http://172.16.20.58:9000/api/roles/ instead 127.0.0.1
Ah, the curl command wasn’t entirely correct. I forgot to escape the last /
character:
curl -u $USER:$PASSWORD -X DELETE http://127.0.0.1:9000/api/roles/%20Stream%2FDashboard%20Editor%Fmembers
This should delete the role " Stream/Dashboard Editor/members" (if that’s the correct name, taken from the GitHub issue).
