Hello guys, I’m trying to send logs from a Debian VPS using Filebeat to Graylog. The Beats input is running, but no active connections are detected (0 active, 26,500 total). I’ve configured Filebeat to point to Graylog’s Beats input on port 5045. No logs appear in Graylog, and connection attempts seem to fail.
OS Information (Graylog Server): Ubuntu (via Docker)
OS Information (Filebeat Client): Debian 12 (kernel 6.1.135-1)
Deployment: Docker Compose
Package Versions:
- MongoDB: 4.4.18
- Elasticsearch: 7.17.0 (docker.elastic.co/elasticsearch/elasticsearch:7.17.0)
- Graylog: 4.3 (graylog/graylog:4.3)
- Filebeat: 7.17.14
Network:
- Filebeat client: Public IP
- Graylog server: Public IP
- Verified Beats input on Graylog is active (port 5045)
- Checked Filebeat service is running
- Confirmed firewall/iptables allows port 5045
- Tried testing with
telnet ip publik graylog server→ connection succes - Checked
journalctl -u filebeatfor logs (no errors found) - Ensured Graylog’s input binds to
0.0.0.0
- Is there anything wrong with my Filebeat or Beats input config?
- Why does Graylog show 0 active connections even though input is running?
- Do I need additional configuration on Docker Graylog or Filebeat to make this connection succeed?
