Hi to all, is there somebody here to what it means by “Widget is not bound to a stream.”
Widget is not bound to a stream?
peter.legista
(peter)
#1
jochen
(Jochen)
#2
This simply means that the widget is not using data from a specific stream, but from all messages which have been indexed, i. e. the same data that you can query using the universal search as in contrast to querying a stream with only a subset of the data.
system
(system)
closed
#3
