after some time, the default index set will changed from 486.0B to 573.0B:
if manually rotate it, it will fall to 486.0B again:
why the default index set become 573.0B after some data has been output to other index sets ?
We’re talking about 486 bytes to 573 bytes…
It’s probably some information which Elasticsearch writes lazily into the indices or maybe it’s because replicas have been allocated lazily.
