where can we delete unwanted savedsearches ?
–charles
–charles
Just found it. thanks
sharing is caring @cdeng
if you write the solution someone else might get the answer to the same question faster …
Yes. Sir.
In the search page, as i have marked with red lines out:
firstly pull down the Saved searches list on the right upper corner and select the saved search which you want to delete
then pull down the actions list at right corner of the Search Actions, select the Delete saved search
–charles.
