Hello Friend,
Can you pls help with the detailed steps of Graylog throttling?
Hello Friend,
Graylog has build in support for throttling for some inputs, check docs. Or you mean something different. Please be more verbose, which graylog version do you use, your configuration and so on.
https://docs.graylog.org/en/4.0/pages/sending_data.html#input-throttling
I am not getting below checkbox option in my Graylog console.
To enable throttling for one of these inputs, edit it in System > Inputs and check the Allow throttling this input checkbox.
I am using below version.
graylog:4.0.5
elasticsearch:6.8.13
mongo:4.0
Thottling is supported only in some inputs, not all:
Graylog Inputs that support throttling:
Which type of input do you use?
It will be OS logs and application logs. you can consider tomcat and syslog.
If you want to use normal syslog, maybe check syslog-ng in middle which support throttling:
Actually we are trying to do throttling on Graylog for Atlassian logs.
