What are "Active connections"?
I have 1 “Active connection” (and 1 total) under my raw TCP input, but earlier in the day, I had 2 and 75 total. What do these numbers mean? Why would I have 75 connections?
  • OS Information: CentOS 7
I have tried searching it up online, but could not find something that fully explains the web UI.
Could anyone please answer this question in simple terms, as I am new to the technical field?
Hello @QueenOfCode
The “total connections” metric is simply the total number of TCP connections that have been established (and possibly have also been closed) over the lifetime of the TCP input. A high number here is no problem (in contrast to a very high number of “active connections” which would hint to clients not properly closing the opened TCP connections).
Thank you, I understand now.
