Hello everyone, here is the simplified network diagram:
[Internet]==[Firewall]==[Switch]==[Graylog]
The firewall is doing 1-to-1 SNAT to the graylog. I can easily access the server from the private subnet. From Internet, however, it timed out (see the following screenshot:)
The graylog config file beginning at HTTP settings:
############### # HTTP settings ############### #### HTTP bind address # # The network interface used by the Graylog HTTP interface. # # This network interface must be accessible by all Graylog nodes in the cluster and by all clients # using the Graylog web interface. # # If the port is omitted, Graylog will use port 9000 by default. # # Default: 127.0.0.1:9000 #http_bind_address = 127.0.0.1:9000 #http_bind_address = [2001:db8::1]:9000 http_bind_address = 192.168.169.100:9000 #### HTTP publish URI # # The HTTP URI of this Graylog node which is used to communicate with the other Graylog nodes in the cluster and by all # clients using the Graylog web interface. # # The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node. # # This configuration setting has to be used if this Graylog node is available on another network interface than $http_bind_address, # for example if the machine has multiple network interfaces or is behind a NAT gateway. # # If $http_bind_address contains a wildcard IPv4 address (0.0.0.0), the first non-loopback IPv4 address of this machine will be used. # This configuration setting *must not* contain a wildcard address! # # Default: http://$http_bind_address/ #http_publish_uri = http://192.168.1.1:9000/ #### External Graylog URI # # The public URI of Graylog which will be used by the Graylog web interface to communicate with the Graylog REST API. # # The external Graylog URI usually has to be specified, if Graylog is running behind a reverse proxy or load-balancer # and it will be used to generate URLs addressing entities in the Graylog REST API (see $http_bind_address). # # When using Graylog Collector, this URI will be used to receive heartbeat messages and must be accessible for all collectors. # # This setting can be overriden on a per-request basis with the "X-Graylog-Server-URL" HTTP request header. # # Default: $http_publish_uri #http_external_uri = #### Enable CORS headers for HTTP interface # # This is necessary for JS-clients accessing the server directly. # If these are disabled, modern browsers will not be able to retrieve resources from the server. # This is enabled by default. Uncomment the next line to disable it. #http_enable_cors = false #### Enable GZIP support for HTTP interface # # This compresses API responses and therefore helps to reduce # overall round trip times. This is enabled by default. Uncomment the next line to disable it. #http_enable_gzip = false # The maximum size of the HTTP request headers in bytes. #http_max_header_size = 8192 # The size of the thread pool used exclusively for serving the HTTP interface. #http_thread_pool_size = 16 ################ # HTTPS settings ################ #### Enable HTTPS support for the HTTP interface # # This secures the communication with the HTTP interface with TLS to prevent request forgery and eavesdropping. # # Default: false #http_enable_tls = true # The X.509 certificate chain file in PEM format to use for securing the HTTP interface. #http_tls_cert_file = /path/to/graylog.crt # The PKCS#8 private key file in PEM format to use for securing the HTTP interface. #http_tls_key_file = /path/to/graylog.key # The password to unlock the private key used for securing the HTTP interface. #http_tls_key_password = secret # Comma separated list of trusted proxies that are allowed to set the client address with X-Forwarded-For # header. May be subnets, or hosts. #trusted_proxies = 127.0.0.1/32, 0:0:0:0:0:0:0:1/128 # List of Elasticsearch hosts Graylog should connect to. # Need to be specified as a comma-separated list of valid URIs for the http ports of your elasticsearch nodes. # If one or more of your elasticsearch hosts require authentication, include the credentials in each node URI that # requires authentication. # # Default: http://127.0.0.1:9200 #elasticsearch_hosts = http://node1:9200,http://user:password@node2:19200 # Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port. # # Default: 10 Seconds #elasticsearch_connect_timeout = 10s # Maximum amount of time to wait for reading back a response from an Elasticsearch server. # # Default: 60 seconds #elasticsearch_socket_timeout = 60s # Maximum idle time for an Elasticsearch connection. If this is exceeded, this connection will # be tore down. # # Default: inf #elasticsearch_idle_timeout = -1s # Maximum number of total connections to Elasticsearch. # # Default: 200 #elasticsearch_max_total_connections = 200 # Maximum number of total connections per Elasticsearch route (normally this means per # elasticsearch server). # # Default: 20 #elasticsearch_max_total_connections_per_route = 20 # Maximum number of times Graylog will retry failed requests to Elasticsearch. # # Default: 2 #elasticsearch_max_retries = 2 # Enable automatic Elasticsearch node discovery through Nodes Info, # see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html # # WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield. # # Default: false #elasticsearch_discovery_enabled = true # Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes, # see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes # # Default: empty #elasticsearch_discovery_filter = rack:42 # Frequency of the Elasticsearch node discovery. # # Default: 30s # elasticsearch_discovery_frequency = 30s # Set the default scheme when connecting to Elasticsearch discovered nodes # # Default: http (available options: http, https) #elasticsearch_discovery_default_scheme = http # Enable payload compression for Elasticsearch requests. # # Default: false #elasticsearch_compression_enabled = true # Enable use of "Expect: 100-continue" Header for Elasticsearch index requests. # If this is disabled, Graylog cannot properly handle HTTP 413 Request Entity Too Large errors. # # Default: true #elasticsearch_use_expect_continue = true # Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine # when to rotate the currently active write index. # It supports multiple rotation strategies: # - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure # - "size" per index, use elasticsearch_max_size_per_index below to configure # valid values are "count", "size" and "time", default is "count" # # ATTENTION: These settings have been moved to the database in 2.0. When you upgrade, make sure to set these # to your previous 1.x settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. rotation_strategy = count # (Approximate) maximum number of documents in an Elasticsearch index before a new index # is being created, also see no_retention and elasticsearch_max_number_of_indices. # Configure this if you used 'rotation_strategy = count' above. # # ATTENTION: These settings have been moved to the database in 2.0. When you upgrade, make sure to set these # to your previous 1.x settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. elasticsearch_max_docs_per_index = 20000000 # (Approximate) maximum size in bytes per Elasticsearch index on disk before a new index is being created, also see # no_retention and elasticsearch_max_number_of_indices. Default is 1GB. # Configure this if you used 'rotation_strategy = size' above. # # ATTENTION: These settings have been moved to the database in 2.0. When you upgrade, make sure to set these # to your previous 1.x settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. #elasticsearch_max_size_per_index = 1073741824 # (Approximate) maximum time before a new Elasticsearch index is being created, also see # no_retention and elasticsearch_max_number_of_indices. Default is 1 day. # Configure this if you used 'rotation_strategy = time' above. # Please note that this rotation period does not look at the time specified in the received messages, but is # using the real clock value to decide when to rotate the index! # Specify the time using a duration and a suffix indicating which unit you want: # 1w = 1 week # 1d = 1 day # 12h = 12 hours # Permitted suffixes are: d for day, h for hour, m for minute, s for second. # # ATTENTION: These settings have been moved to the database in 2.0. When you upgrade, make sure to set these # to your previous 1.x settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. #elasticsearch_max_time_per_index = 1d # Disable checking the version of Elasticsearch for being compatible with this Graylog release. # WARNING: Using Graylog with unsupported and untested versions of Elasticsearch may lead to data loss! #elasticsearch_disable_version_check = true # Disable message retention on this node, i. e. disable Elasticsearch index rotation. #no_retention = false # How many indices do you want to keep? # # ATTENTION: These settings have been moved to the database in 2.0. When you upgrade, make sure to set these # to your previous 1.x settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. elasticsearch_max_number_of_indices = 20 # Decide what happens with the oldest indices when the maximum number of indices is reached. # The following strategies are availble: # - delete # Deletes the index completely (Default) # - close # Closes the index and hides it from the system. Can be re-opened later. # # ATTENTION: These settings have been moved to the database in 2.0. When you upgrade, make sure to set these # to your previous 1.x settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. retention_strategy = delete # How many Elasticsearch shards and replicas should be used per index? Note that this only applies to newly created indices. # ATTENTION: These settings have been moved to the database in Graylog 2.2.0. When you upgrade, make sure to set these # to your previous settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. elasticsearch_shards = 4 elasticsearch_replicas = 0 # Prefix for all Elasticsearch indices and index aliases managed by Graylog. # # ATTENTION: These settings have been moved to the database in Graylog 2.2.0. When you upgrade, make sure to set these # to your previous settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. elasticsearch_index_prefix = graylog # Name of the Elasticsearch index template used by Graylog to apply the mandatory index mapping. # Default: graylog-internal # # ATTENTION: These settings have been moved to the database in Graylog 2.2.0. When you upgrade, make sure to set these # to your previous settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. #elasticsearch_template_name = graylog-internal # Do you want to allow searches with leading wildcards? This can be extremely resource hungry and should only # be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html allow_leading_wildcard_searches = false # Do you want to allow searches to be highlighted? Depending on the size of your messages this can be memory hungry and # should only be enabled after making sure your Elasticsearch cluster has enough memory. allow_highlighting = false # Analyzer (tokenizer) to use for message and full_message field. The "standard" filter usually is a good idea. # All supported analyzers are: standard, simple, whitespace, stop, keyword, pattern, language, snowball, custom # Elasticsearch documentation: https://www.elastic.co/guide/en/elasticsearch/reference/2.3/analysis.html # Note that this setting only takes effect on newly created indices. # # ATTENTION: These settings have been moved to the database in Graylog 2.2.0. When you upgrade, make sure to set these # to your previous settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. elasticsearch_analyzer = standard # Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range # calculations) based on a best-effort to restrict the runtime of Elasticsearch operations. # Default: 1m #elasticsearch_request_timeout = 1m # Global timeout for index optimization (force merge) requests. # Default: 1h #elasticsearch_index_optimization_timeout = 1h # Maximum number of concurrently running index optimization (force merge) jobs. # If you are using lots of different index sets, you might want to increase that number. # Default: 20 #elasticsearch_index_optimization_jobs = 20 # Time interval for index range information cleanups. This setting defines how often stale index range information # is being purged from the database. # Default: 1h #index_ranges_cleanup_interval = 1h # Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't # need to run very often. # Default: 1h #index_field_type_periodical_interval = 1h # Batch size for the Elasticsearch output. This is the maximum (!) number of messages the Elasticsearch output # module will get at once and write to Elasticsearch in a batch call. If the configured batch size has not been # reached within output_flush_interval seconds, everything that is available will be flushed at once. Remember # that every outputbuffer processor manages its own batch and performs its own batch write calls. # ("outputbuffer_processors" variable) output_batch_size = 500 # Flush interval (in seconds) for the Elasticsearch output. This is the maximum amount of time between two # batches of messages written to Elasticsearch. It is only effective at all if your minimum number of messages # for this time period is less than output_batch_size * outputbuffer_processors. output_flush_interval = 1 # As stream outputs are loaded only on demand, an output which is failing to initialize will be tried over and # over again. To prevent this, the following configuration options define after how many faults an output will # not be tried again for an also configurable amount of seconds. output_fault_count_threshold = 5 output_fault_penalty_seconds = 30 # The number of parallel running processors. # Raise this number if your buffers are filling up. processbuffer_processors = 5 outputbuffer_processors = 3 # The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor. # See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details # When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size), # this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating. # Default: 5000 #outputbuffer_processor_keep_alive_time = 5000 # The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set # Default: 3 #outputbuffer_processor_threads_core_pool_size = 3 # The maximum number of threads to allow in the pool # Default: 30 #outputbuffer_processor_threads_max_pool_size = 30 # UDP receive buffer size for all message inputs (e. g. SyslogUDPInput). #udp_recvbuffer_sizes = 1048576 # Wait strategy describing how buffer processors wait on a cursor sequence. (default: sleeping) # Possible types: # - yielding # Compromise between performance and CPU usage. # - sleeping # Compromise between performance and CPU usage. Latency spikes can occur after quiet periods. # - blocking # High throughput, low latency, higher CPU usage. # - busy_spinning # Avoids syscalls which could introduce latency jitter. Best when threads can be bound to specific CPU cores. processor_wait_strategy = blocking # Size of internal ring buffers. Raise this if raising outputbuffer_processors does not help anymore. # For optimum performance your LogMessage objects in the ring buffer should fit in your CPU L3 cache. # Must be a power of 2. (512, 1024, 2048, ...) ring_size = 65536 inputbuffer_ring_size = 65536 inputbuffer_processors = 2 inputbuffer_wait_strategy = blocking # Enable the disk based message journal. message_journal_enabled = true # The directory which will be used to store the message journal. The directory must be exclusively used by Graylog and # must not contain any other files than the ones created by Graylog itself. # # ATTENTION: # If you create a seperate partition for the journal files and use a file system creating directories like 'lost+found' # in the root directory, you need to create a sub directory for your journal. # Otherwise Graylog will log an error message that the journal is corrupt and Graylog will not start. message_journal_dir = /var/lib/graylog-server/journal # Journal hold messages before they could be written to Elasticsearch. # For a maximum of 12 hours or 5 GB whichever happens first. # During normal operation the journal will be smaller. #message_journal_max_age = 12h #message_journal_max_size = 5gb #message_journal_flush_age = 1m #message_journal_flush_interval = 1000000 #message_journal_segment_age = 1h #message_journal_segment_size = 100mb # Number of threads used exclusively for dispatching internal events. Default is 2. #async_eventbus_processors = 2 # How many seconds to wait between marking node as DEAD for possible load balancers and starting the actual # shutdown process. Set to 0 if you have no status checking load balancers in front. lb_recognition_period_seconds = 3 # Journal usage percentage that triggers requesting throttling for this server node from load balancers. The feature is # disabled if not set. #lb_throttle_threshold_percentage = 95 # Every message is matched against the configured streams and it can happen that a stream contains rules which # take an unusual amount of time to run, for example if its using regular expressions that perform excessive backtracking. # This will impact the processing of the entire server. To keep such misbehaving stream rules from impacting other # streams, Graylog limits the execution time for each stream. # The default values are noted below, the timeout is in milliseconds. # If the stream matching for one stream took longer than the timeout value, and this happened more than "max_faults" times # that stream is disabled and a notification is shown in the web interface. #stream_processing_timeout = 2000 #stream_processing_max_faults = 3 # Since 0.21 the Graylog server supports pluggable output modules. This means a single message can be written to multiple # outputs. The next setting defines the timeout for a single output module, including the default output module where all # messages end up. # # Time in milliseconds to wait for all message outputs to finish writing a single message. #output_module_timeout = 10000 # Time in milliseconds after which a detected stale master node is being rechecked on startup. #stale_master_timeout = 2000 # Time in milliseconds which Graylog is waiting for all threads to stop on shutdown. #shutdown_timeout = 30000 # MongoDB connection string # See https://docs.mongodb.com/manual/reference/connection-string/ for details mongodb_uri = mongodb://localhost/graylog # Authenticate against the MongoDB server # '+'-signs in the username or password need to be replaced by '%2B' #mongodb_uri = mongodb://grayloguser:secret@localhost:27017/graylog # Use a replica set instead of a single host #mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog?replicaSet=rs01 # DNS Seedlist https://docs.mongodb.com/manual/reference/connection-string/#dns-seedlist-connection-format #mongodb_uri = mongodb+srv://server.example.org/graylog # Increase this value according to the maximum connections your MongoDB server can handle from a single client # if you encounter MongoDB connection problems. mongodb_max_connections = 1000 # Number of threads allowed to be blocked by MongoDB connections multiplier. Default: 5 # If mongodb_max_connections is 100, and mongodb_threads_allowed_to_block_multiplier is 5, # then 500 threads can block. More than that and an exception will be thrown. # http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier mongodb_threads_allowed_to_block_multiplier = 5 # Email transport #transport_email_enabled = false #transport_email_hostname = mail.example.com #transport_email_port = 587 #transport_email_use_auth = true #transport_email_auth_username = you@example.com #transport_email_auth_password = secret #transport_email_subject_prefix = [graylog] #transport_email_from_email = graylog@example.com # Encryption settings # # ATTENTION: # Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible. # Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS #transport_email_use_tls = true # Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS # This is deprecated on most SMTP services! #transport_email_use_ssl = false # Specify and uncomment this if you want to include links to the stream in your stream alert mails. # This should define the fully qualified base url to your web interface exactly the same way as it is accessed by your users. #transport_email_web_interface_url = https://graylog.example.com # The default connect timeout for outgoing HTTP connections. # Values must be a positive duration (and between 1 and 2147483647 when converted to milliseconds). # Default: 5s #http_connect_timeout = 5s # The default read timeout for outgoing HTTP connections. # Values must be a positive duration (and between 1 and 2147483647 when converted to milliseconds). # Default: 10s #http_read_timeout = 10s # The default write timeout for outgoing HTTP connections. # Values must be a positive duration (and between 1 and 2147483647 when converted to milliseconds). # Default: 10s #http_write_timeout = 10s # HTTP proxy for outgoing HTTP connections # ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal # HTTP connections with other nodes does not go through the proxy. # Examples: # - http://proxy.example.com:8123 # - http://username:password@proxy.example.com:8123 #http_proxy_uri = # A list of hosts that should be reached directly, bypassing the configured proxy server. # This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards. # Any host matching one of these patterns will be reached through a direct connection instead of through a proxy. # Examples: # - localhost,127.0.0.1 # - 10.0.*,*.example.com #http_non_proxy_hosts = # Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch # on heavily used systems with large indices, but it will decrease search performance. The default is to optimize # cycled indices. # # ATTENTION: These settings have been moved to the database in Graylog 2.2.0. When you upgrade, make sure to set these # to your previous settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. #disable_index_optimization = true # Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch # on heavily used systems with large indices, but it will decrease search performance. The default is 1. # # ATTENTION: These settings have been moved to the database in Graylog 2.2.0. When you upgrade, make sure to set these # to your previous settings so they will be migrated to the database! # This configuration setting is only used on the first start of Graylog. After that, # index related settings can be changed in the Graylog web interface on the 'System / Indices' page. # Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration. #index_optimization_max_num_segments = 1 # The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification # will be generated to warn the administrator about possible problems with the system. Default is 1 second. #gc_warning_threshold = 1s # Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds. #ldap_connection_timeout = 2000 # Disable the use of SIGAR for collecting system stats #disable_sigar = false # The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second) #dashboard_widget_default_cache_time = 10s # For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number # of threads available for this. Increase it, if '/cluster/*' requests take long to complete. # Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users. proxied_requests_thread_pool_size = 32 # The server is writing processing status information to the database on a regular basis. This setting controls how # often the data is written to the database. # Default: 1s (cannot be less than 1s) #processing_status_persist_interval = 1s # Configures the threshold for detecting outdated processing status records. Any records that haven't been updated # in the configured threshold will be ignored. # Default: 1m (one minute) #processing_status_update_threshold = 1m # Configures the journal write rate threshold for selecting processing status records. Any records that have a lower # one minute rate than the configured value might be ignored. (dependent on number of messages in the journal) # Default: 1 #processing_status_journal_write_rate_threshold = 1 # Configures the prefix used for graylog event indices # Default: gl-events #default_events_index_prefix = gl-events # Configures the prefix used for graylog system event indices # Default: gl-system-events #default_system_events_index_prefix = gl-system-events # Automatically load content packs in "content_packs_dir" on the first start of Graylog. #content_packs_loader_enabled = false # The directory which contains content packs which should be loaded on the first start of Graylog. #content_packs_dir = data/contentpacks # A comma-separated list of content packs (files in "content_packs_dir") which should be applied on # the first start of Graylog. # Default: empty #content_packs_auto_install = grok-patterns.json # The allowed TLS protocols for system wide TLS enabled servers. (e.g. message inputs, http interface) # Setting this to an empty value, leaves it up to system libraries and the used JDK to chose a default. # Default: TLSv1.2,TLSv1.3 #enabled_tls_protocols= TLSv1.2,TLSv1.3
The log:
2020-02-15T17:09:49.579+08:00 INFO [NetworkListener] Started listener bound to [192.168.169.100:9000] 2020-02-15T17:09:49.581+08:00 INFO [HttpServer] [HttpServer] Started. 2020-02-15T17:09:49.581+08:00 INFO [JerseyService] Started REST API at <192.168.169.100:9000> 2020-02-15T17:09:49.581+08:00 INFO [ServiceManagerListener] Services are healthy 2020-02-15T17:09:49.583+08:00 INFO [ServerBootstrap] Services started, startup times in ms: {InputSetupService [RUNNING]=2, JobSchedulerService [RUNNING]=38, OutputSetupService [RUNNING]=38, JournalReader [RUNNING]=39, EtagService [RUNNING]=39, BufferSynchronizerService [RUNNING]=39, UrlWhitelistService [RUNNING]=50, MongoDBProcessingStatusRecorderService [RUNNING]=52, GracefulShutdownService [RUNNING]=55, ConfigurationEtagService [RUNNING]=95, KafkaJournal [RUNNING]=112, StreamCacheService [RUNNING]=128, LookupTableService [RUNNING]=163, PeriodicalsService [RUNNING]=221, JerseyService [RUNNING]=28614} 2020-02-15T17:09:49.584+08:00 INFO [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE] 2020-02-15T17:09:49.584+08:00 INFO [ServerBootstrap] Graylog server up and running. 2020-02-15T17:09:49.585+08:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
Thanks in advance for any help.
