Unable to log into web UI and [TOO_MANY_REQUESTS/12/disk usage exceeded
Hi, my symptoms are that I can’t log into the WEB UI, error message: There was an error fetching a resource: Service unavailable, Authentication service unavailable.
I have two servers, Redhat 8.8, one running Graylog 5.0.9, the other opensearch (or elasticsearch) 5.3.7
When I try to log into the web UI I get:
Error - the server returned: 503 - There was an error fetching a resource: Service Unavailable. Additional information: Authentication service unavailable
I see this in server.log:
index [syslog_0], id [543bc63a-c930-11ed-b4be-005056a5f381], message [OpenSearchException[OpenSearch exception [type=cluster_block_exception, reason=index [syslog_0] blocked by: [TOO_MANY_REQUESTS/12/disk usage exceeded flood-stage watermark, index has read-only-allow-delete block];]]]
If someone could put me on the path to fix this I would really appreciate it. Each time my server team patches the OS / App they have had to increase disk space, this condition started after patching.
Greetings. This mean the disk space usage where elasticsearch/opensearch is running has exceeded the high watermark threshold, which is 90% i believe. See Fix common cluster issues | Elasticsearch Guide [7.17] | Elastic
You’ll need to free up space. My guess is the retention policies in graylog are allowing more data to be stored than there is available on the disk.
