it works fine, if it produces a timestamp_test field and the content of that field is the correct event time in UTC. Once you get it working, you can change the extractor so that it saves the result in the timestamp field, and see if it still produces the right time. In my experience, for some reason this second step can be also problematic.
Hi, thanks both. I did it but new logs are same than others, it isn’t converting
Example message
2017-06-15T06:38:35.155Z
Extractor configuration:
Extractor type: Copy input
Source field: timestamp
The entire input will be copied verbatim.
Condition: Always try to extract
Store as field: timestamp
Extraction strategy: Copy
Extractor title: Timestamp
Add converter: Convert Date and format string:
Format String: yyyy-MM-dd HH:mm:ss
Time Zone: Madrid
Locale: Spanish
I save it, after I went to Stream (or dashboard main) and timestamp from new logs are same (like that 2017-06-15T06:38:35.155Z)
