SSO plugni and role mapping
Is there any way to map users, that came with sso auth to addnitional roles to grant acees to a stream?
Hi
I haven’t used the sso yet, but I find a lot of things about the plugin here.
It contains some releted infromation for you.
http://docs.graylog.org/en/2.4/pages/users_and_roles/external_auth.html
So as I see, you have to create the user, after that, you can use roles to set rights on streams.
Thanks. I hope there is any way to automate it. I’l try to do it with api calls.
