what is the best way to send apache logs to graylog
I tried using the sidecar but was unable to I get the following message
sudo start graylog-sidecar
sudo: start: command not found
I don’t even know what OS you are running on, what instructions you have followed for install…for instance instead of start
, with Ubuntu you might use systemctl
Try this
sudo systemctl start graylog-sidecar
