Reopen index command
how can i reopen index in graylog 5.2.2
I have try the follow command
curl -v -X POST “http://127.0.0.1:9200/api/indexes/reopen?indexNames=graylog_242
curl -v -X POST “http://127.0.0.1:9200/api/cluster/indices/graylog_242/reopen
but not work
any one helps
tks a lot
What are you trying to accomplish by reopening an index, it’s not something Graylog is generally built to require or even really support?
to search old data in close index
it can be reopen at web
but if it can be reopen use command
because need to reopen many index at once
not easy to do in web
I would use the Graylog API to automate it rather than the opensearch API. The easiest way to find out the required API call is to open the inspector in your browser and just look for the API call in the network tab when you click it manually via the gui. This will ensure if there any steps on the Graylog side that they will also be completed.
try it by myself
curl -v -X POST -H “Content-Type: application/json” -H “X-Requested-By: XMLHttpRequest” -u user:password http://127.0.0.1:9000/api/system/indexer/indices/graylog_245/reopen
thanks for your help
