Pipeline rule to capture a set of servers. Having trouble with the \d Numerical part.
rule “Detect CAS Servers”
regex("\b(cb|sl)-srv-cas\d*\b", to_string($message.HostName)).matches == true
Fails due to the \d*
regex("\b(cb|sl)-srv-cas(1|2)\b", to_string($message.HostName)).matches == true
(1|2) Would achieve what I need but wanted to check on the support of /d.
