Reading filename and appending to all logs
I have filebeat setup to read log files from a specific directory.
My issue is that the systemID is not in the logs. Rather, it is appended in the filename.
e.g. 551904.log
I need each line in the log to be tagged to a fieldname(systemID) with the value of 551904 so that I know where the log came from.
Any suggestions on how I can achieve this in graylog? Thanks!
In the filebeat configuration on the client you can set fields to include in the message going to Graylog - here is an example windows version.
filebeat:
  inputs:
##### example input with log name
    - type: log
      enabled: true
      include_lines: ['Authorization']
      exclude_lines: ['Header','^#']
      fields:
        SystemID: 551904
      ignore_older: 72h
      paths:
        - C:\windows\logs\example\551904.log
This solution wouldn’t be efficient for multiple machines with unique systemID’s but it’s a start.
